Physics 101 lab help should be easy
  • Thread starter Thread starter dirtbird
    Lab Physics
The discussion centers on solving a projectile motion problem from a Physics 101 lab involving a ball shot from a height of 10 cm at a 10-degree angle. The initial calculations yielded an incorrect initial velocity of 7.44 m/s, while the correct value derived from the projectile motion equations is 6.66 m/s. Key equations utilized include x = v*cos(θ)*t and y = v*sin(θ)*t - (1/2)*g*t², where g is the acceleration due to gravity (9.8 m/s²). The participants emphasized the importance of eliminating time from the equations to derive a function of y in terms of x.
  • Understanding of basic projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of kinematic equations in physics
  • Ability to manipulate algebraic equations
  • Study the derivation of projectile motion equations
  • Learn how to apply trigonometric identities in physics problems
  • Explore resources on HyperPhysics for additional explanations
  • Practice solving projectile motion problems with varying angles and heights
Students enrolled in introductory physics courses, educators teaching projectile motion, and anyone seeking to improve their understanding of kinematics and algebraic manipulation in physics.
dirtbird
Okay, I'm not sure how I'm going to do this, but let's try. it is my third week of physics 101, and everything makes perfect sense, or so i thought. Our second lab, we used a ball shooter, and we shot one ball from a table onto the floor, one ball straight into the air, and one ball at a 10 degree angle. Guess which one I'm having problems with!
anyway, we shot the ball from a 10 cm height, at 10degrees, and the ball landed 199 cm away from the point of origin. So i set the problem up like this:
Yfinal= -.1 m
Yinitial= 0 m
Vyinitial= unknown
Vyfinal= unknown
A=-9.8m/s sq
T= unknown
Xfinal= 1.99 m
Xinitial= 0 m
Vx= unknown
A= 0 m/s sq
T= unknown
I have tried to explain how i tried to solve this with text, but i think i am not advanced enough to do that! essentially, i did some messy stuff with sin and cos, and came out with an initial velocity of 7.44 m/s. this is way off from the 5.75 i got for the first two experiments, and my lab partners got 2 completely different answers. I was wondering if it would be possible for someone to try to help me set up the problem. I can post what i did before if i need to, but it is proving very difficult! Thanks for any help
charla
I may not be the best person to help you. I just started to learn physics on my own, over summer break.
Here goes nothing:
I think you use the basic equation for projectile motion. (ignoring air resistance)
x = v*cos(10)*t
y=v*sin(10)*t – (1/2)*g*t^2
v is the initial velocity and g is acceleration due to gravity (g=9.8 m/s^2)
setting x = 1.99m and solving for t we get the time of impact
t= 1.99/( v*cos(10))
setting y = -.10 m in the second equation and substituting for t:
-.10 = v*sin(10)*(1.99/( v*cos10))– (1/2)*g*(1.99/( v*cos10))^2
.10 + tan(10)*1.99 = (1/2)*g*(1.99/( v*cos10))^2
v^2=[(1/2)*g*(1.99/( v*cos10))^2] / [.10 + tan(10)*1.99]
v=6.66 m/s
Hope this helps you.
Someone should check my work I may have made some careless mistake.
I see that Suicidal inserted numbers into the relations before he did the algebra. In case that is not clear to you, let me do it without doing the substitutions so you can see why the relation is as it is.
You have:
(1)...x(t)-x0=v0cos(θ)t
(2)...y(t)-y0=v0sin(θ)t-(1/2)gt2
Now, you didn't measure the time, but that's OK because we can eliminate the time to get y as a function of x.
From eq. (1):
t=(x-x0)/(v0cos(θ))
Insert that into (2) to get:
y-y0=v0sin(θ)(x-x0)/(v0cos(θ))-(1/2)g((x-x0)/(v0cos(θ))2
Since you used x0=y0=0m, we can drop those. Doing a little simplification yields:
y(x)=(v0tan(θ))x-(g/(2cos(θ)))x2
which is a downward-opening parabola, as expected. That equation should also be in your book.
Here's a nifty site called HyperPhysics for more:
http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html#tra2
Awesome, thanks a lot you guys! What i did it turns out was right, but it was much more complicated than what you guys did, so i think i made a math mistake somewhere in it. My professor said she would give me full credit for what i did, but i am personally not satisfied. . I'm going to work on it some more with the formulas you guys gave me, and i'll bookmark that awesome website, so hopefully i won't have to ask any more lame questions :P. Thanks again!
charla
  • · Replies 35 ·
  • · Replies 17 ·
14K
