Applying Physics to Pinball Machines: A Comprehensive Guide
  • Thread starter Thread starter Shaheemie
    Machines Physics
A user seeks resources on the application of physics in pinball machines for an 11th grade Honors Physics class. Key concepts discussed include Newton's third law, impulse momentum equations, and kinematic equations relevant to the motion of the pinball. Specific equations are suggested for analyzing how the ball interacts with flippers and the trajectory of its movement. The conversation emphasizes the importance of understanding basic physics principles without delving too deeply into complex theories. Overall, the discussion provides a foundation for applying physics concepts to the mechanics of pinball machines.
Shaheemie
Do any of you know of a good site, or just a general site, where physics is applied to pinball machines? I 'm having trouble finding any, if there are any out there, that is.
What would you like to know? There is a couple of things about pinball machines related to physics (and by a couple of things I mean, well... everything).
Well, I don't need it in great depth. I'm in an 11th grade Honors Physics class and there is only so much we can cover and understand. Obviously basics is needed. That would be really helpful, thank you. I trust your judgement. If I have any trouble, I'll just yell. :P
I'm guessing you are in Physics C (Mechanics). You should look into Newton's third law (law of conservation). This can represent how the pinball will bounce off of walls. You can also look at impulse momentum equations F/delta t = M /delta V. This can be applied to when the flipper hits the ball. You can then look at d = 1/2gt^2. This equation can (when applied on a tilted axis, because the ball is not dropping straight down) provide a distance that the ball will travel downwards in a given amount of time, or you can use the equation v_f^2 = v_o^2 + 2ad for the velocity of a ball.
Good luck!
That's fantastic. That's just what I needed.
Thank you!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
