Physics behind voltage regulators
  • Thread starter Thread starter littlebilly91
    Physics Voltage
A voltage regulator cannot create a -5V output from just a +5V and ground; the LM7905 requires a raw negative voltage input. To generate a -5V signal, a DC to DC converter or a switched capacitor converter is necessary, as there is no single-chip solution for this conversion. Creating a "virtual ground" can allow for obtaining both +5V and -5V from a higher positive voltage, such as +12V. It is crucial to understand the reference points in voltage systems, as calling something "ground" can be misleading. Overall, achieving -5V from +5V requires additional components beyond standard voltage regulators.
littlebilly91
Hello,
I was given a voltage regulator today (to provide -5V to an op amp). I was told that I could create a -5V signal from a +5V and a ground. I was told that the ground was converted to a neutral level. I understand what that means, but not why or how it works. Could someone explain that to me how this works in detail? I am particularly interested in the physics behind it. It is an LM7905 if anyone is curious.
Thanks,
Chet
You cannot create -5V from +5V and ground using a 7905. 7905 will take a raw negative voltage more negative than -7V together with the 0V(ground) to regulate to -5V output. But no way can a 7905 take only +5V and 0V(ground) and get -5V.
Sorry, I listed the wrong one ( was given 2). LM7805 does the trick, yeah?
No, a 7805 will give you +5V out.
Converting a positive voltage to something negative is a bit tricky. One way of doing it is to create a "virtual ground", this will allow you to e.g. get +5 and -5V from a +12V supply.
AFAIK there is no single-chip solution for creating -5V from a +5V supply.
There must be a DC to DC converter that can convert +5V to -5V. Just that OP name 7905 on the first post. BUT not a single IC without monkeying with inductors and other components.
Actually, if you are given +5V and 0V, you can change reference and use +5V as common and 0V(ground ) as -5V. You have to be very careful to call anything ground. In a straight sense, it is all relative.
Back to the OP, there is no way to get -5V from either 7805 or 7905 if you have to keep 0V as ground from +5V.
there are switched capacitor converters that'll do it
if you don't need much current.
check Linear Technology's LTC 1983-3/LTC1983-5
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 32 ·
  • · Replies 32 ·
  • · Replies 38 ·
