Calculating Buoyancy and Weight in a Sinking Ship Diorama
  • Context: Undergrad
  • Thread starter Thread starter nbontra
    Physics Ship
The discussion revolves around the physics of buoyancy and weight in the context of constructing a diorama of a sinking ship. Participants explore the calculations necessary to determine the weight of the toy ship, the effects of water volume and tank size on sinking rates, and the mechanics of using air to raise the ship underwater.
  • One participant questions whether the weight of the toy ship can be determined solely by scale, suggesting that the size ratio might be a factor.
  • Another participant emphasizes the importance of the ship's volume and mass, proposing a method to measure the volume through water displacement.
  • It is noted that the ship must weigh more than the water it displaces to sink, with a specific mention of fresh water's weight being 1 kg per liter.
  • Participants discuss the need to add weights to the ship to ensure it sinks properly.
  • There is mention of using air from a hose to raise the ship, with a claim that each liter of air provides 1 kg of lift.
  • Concerns are raised about the effects of air bubbles trapped in the ship's details, which could complicate buoyancy calculations.
  • One participant introduces the idea of considering viscous effects and terminal velocity, relating these to the surface area of the ship and the density differences between the ship and the displaced water.
  • A suggestion is made to experiment with simpler shapes, like a submarine, for better results.
Participants express various viewpoints on the calculations and methods for determining buoyancy and weight, indicating that multiple competing views remain without a clear consensus on the best approach.
Some limitations are noted, such as the complexity of accurately measuring the volume of irregular shapes and the potential impact of air bubbles on buoyancy. The discussion does not resolve these issues.
This discussion may be of interest to art students, hobbyists in model making, and individuals exploring the principles of buoyancy and fluid dynamics in practical applications.
nbontra
I'm constructing a diorama of a ship sinking, and I haven't been able to find any details on the physics behind it. I'm an art student, so my knowledge in physics is limited to what I read here and in a few books at home.
I'll most likely construct a fish tank that is 4'x1'x1' to contain the water and toy ship. My question is to what formula I would use to determine how heavy to make the toy ship. Is it just a scale issue? Where I could just use the size ratio to figure out the weight? If I go that route, will the amount of water or the size of the tank affect the rate at which it sinks?
Also, I'll be using an air compressor hose to attempt to raise the ship while it is sinking. How does one determine how much air can raise a certain amount of weight underwater?
Thanks!
It depends on the volume and mass of the ship. Unless it is a very simple crude shape it is going to be difficult to calculate the volume of the ship.
To measure the volume fill a container to the top with water, push the model under the water and cathc the extra water that overlfows. The volume of this water is the displacement.
Fresh (ie not salt) water weighs 1Kg / litre so your boat has to weigh more than 1Kg for each litre it displaces.
You will probably have to add weights to make it sink.
Then to make it float again you add air from the hose. For every litre of air you add you get 1kg of lift.
With a detailed model you are also going to have problems with air bubbles caught in small details.
You are probabaly ging to have to experiment to get it right.
Viscous effects, those which influence the resistance of the ship to the water, are related to the surface area of the ship exposed to the water, and determine a terminal velocity for the sinking ship. Buoyancy, or lack of it, determines the acceleration component of sinking, and is related to the density of the ship minus the density of water displaced by it, as mgb_phys mentioned. Take care to consider (or eliminate) any air bubbles, also using Archimedes' principle! A simple shape that you may want to experiment with is that of a submarine rather than a ship.
thanks for the info, i surely appreciate it!
  • · Replies 17 ·
11K
  • · Replies 23 ·
  • · Replies 52 ·
