Physics Project (Egg Drop, again)
The physics project involves an egg drop challenge with strict restrictions affecting scoring, including time of fall, accuracy, height, construction materials, and survivability of the egg. Participants are encouraged to brainstorm creative solutions that balance these constraints, such as using parachutes to slow descent and innovative catching devices to ensure the egg lands accurately. Suggestions include utilizing deformable materials like Styrofoam for cushioning and exploring liquid or gel-based landing pads to reduce impact. The discussion highlights the importance of engineering effort and creativity in design while adhering to the project's rules. Overall, the goal is to successfully drop the egg from a height of about 20 feet without breaking it and within the specified scoring criteria.
deficiency4math
hi,
I just got my project from physics, and its that annoying, classic egg drop situation. I have a lot of restrictions, and its out of 20 points, so its pretty hard. I would LOVE it if anyone of you could maybe contribute any ideas and suggestions and such. Thanks a bunch!
Restrictions and Point Deductions:
Time:
Time of fall is less than 2 seconds= no deduction
Time of fall is between 2 seconds and 4 seconds= -1 pt
Time of fall is between 4 seconds and 10 seconds= -2 pts
Time of fall is greater than 10 seconds= -3pts
Accuracy:
If landing and at rest within 40cm squared target area on the ground= no deduction
If landing and at rest outside 40cm sqared target area on ground= -1pt deduction
Height:
If final resting place of egg is within 5 cm of ground level= no deduction
If final resting place of egg is between 5 cm and 10 cm off the ground= -1 pt
If final resting place of egg is between 10cm and 35cm off the ground= -3 pts
If final resting place of egg is greater than 35 cm off the ground= -4 pts
Construction
Use of padding around the egg= -3 pts
Use of catching device with a base greater than 400cm squared= -1 pt
Use of catching device with a base greater than 1200cm squared= -2 pts
Use of a catching device higher than 30cm= -1 pt
Use of any type of casing/box/bottle/enclosing covering the egg= -1 pt
Use of duct tape/any type of tape= -2 pts
Survivability
If egg cracks but does not leak= -1 pt
If egg breaks and leakage occurs= -4 pts
Engineering Effort
If the device shows minimal effort/though= -5 pts
!Remember that this project is out of 20 pts, so to get an A, I can only miss 1!
(I just want to get some ideas of how other pros would do it, so suggestions and comments and idea would be greatly appreciated.)
Thanks Again!
From what height is the egg to be dropped?
Is the way the egg is released restricted in any way? (who/what drops it?)
Please clarify - I think you mean 400 square cm? As in a square with 20cm to a side?
Each restriction is obviously directed at a few "clasic" solutions (pad the egg, slow the fall, pad the landing). I'm guessing that the best mark will be something that uses both permitted techniques, but to a limited degree...
Add a parachute that slows the fall to just under 2 seconds, and ...
Construct a catching device just under 400 square cm (?) and just under 30cm high, that ends up holding the egg just under 5cm from the ground.
off a ledge on the second story of a gym. Not THAT high, maybe 20 feet, more or less...
It is not restricted... I drop the egg, how many ways are there to drop an egg?
Ya sry that's what I meant
Thanks
Here's an idea and story for you. Indy racing has a lot of scientists/engineers working to make it a safer sport for the drivers. They noticed at one point many drivers were getting head injuries in rear-end accidents. Typical reaction would be to put more foam behind the drivers head for padding - wrong answer. The foam they were using had too much 'bounce' and was a contributing factor.
So a deformable foam that offered a plastic collision (not elastic) would use up the kinetic energy in its deformation would also allow the egg to be closer to the ground as it deformed, a 2-for-1 deal!
Styrofoam (expanded polystyrene) would be a good choice and comes in different densities that would offer different characteristics. Does that count as padding? Hopefully less than regular egg-crate foam would.
ya, any type of Styrofoam would be considered a padding. I just learned that fluids and gas are NOT considered padding. Soooooo... I was thinking about maybe a pool or something. Also, to solve the accuracy issue, a net with a sag in the middle would make the egg roll to the middle, erasing the issue of accuracy.
You mean an airbag is allowed but styrofoam isn't?
As Smokey Yunick of NASCAR fame would say, "it ain't cheating if you don't get caught"
Its been years for me, but I think I'd challenge myself to use my old Dukes of Hazzard lunchbox as the container with little more than the sandwich bags and some bread and see if I could pull it off. Gotta have a challenge you know! :smile:
Dukes of Hazzard? I had a Star Wars lunch box. Damn I wish I still had it.
My mom thought Star Wars would be a violent influence. So instead my fragile little mind was influenced by a TV show about moonshining, running from cops, and driving like a manic. :smile:
Besides, they had a Dukes of Hazzard reunion here in Atlanta last year, Cooter was a GA congressman for a while, has his own musem in some resturant with a few hundred peices of memorabilia, and there's a new movie coming out that Rhys Millen was a stunt driver in staring Johnny Knoxville, Stifler, and Jessica Simpson. Go to an automotive event down here in the south and you're bound to learn all kinds of minutia.
I'm curious what the OP has come up with for a plan.
Uh, I know a way to go about this that would only lose you one point. You'd have to use a box, see, is the problem. But other than that, everything else is legal.
Again, as the person said earlier, I'm pretty sure this innovation was come up with for race car drivers. The driver is strapped in a seat that is suspended on all sides.
So. You build a box of wood or somesuch, doesn't really matter so long as it's stable, wrap the egg in a twist of nylon (women's stockings, for example) and nail the ends of the nylon twist to opposing sides of the box. Alternately, do the same thing with a box but stick the egg inside some sort of egg-shaped plastic container in the middle and string it up in the center by elastic bands stuck to each of the eight corners. (This is the professional way to do it, and probably a bit more expensive/hard to come by. I like the nylon one, and it works most of the time.)
I like that idea, but I think it would be hard to make it land acurately. You could perhaps add some streamers or some kind of open parachute to slow the fall slightly and stop the box from tumbling... that might make it land squarely. Perhaps a catching device could also be used?
It might be tricky (but doable, I think) to have the egg finish less than 5cm from the ground.
As far as the encasing rule goes, what if you used a rigid but open cage instead of a box? Like a cubical frame made of aluminium?
frames count as an inclosing :mad: :devil:
-1 pt deduction? so --1? so +1? :-p
Offhand I'd try a combo solution as was previously suggested - a small pan of water, less than about 10" deep (25 cm), below the minimum area specified, with some sort of soft rubber/jelly pad at the bottom of the pan, up to 2" worth (5 cm). (You might be able to use jello, but I think water on top would dissolve it). Design a parachute system that will allow you to reliably hit the pan of water without exceeding the time limit. You'll probably have to glue the egg to the parachute lines, I suppose. Add an aiming system ( a long string and a weight will do) - if you're really paranoid, make the parachute follow the string down so you know you'll hit the target (who knows how windy it'll be?).
Egg drops, water splacshes, and hopefully it hits the rubber/jelly pad slowly enough not to break.
I'd start by finding what an egg can actually take - in terms of impulse. Add an adequate safety margin too.
Then I'd make a device that catches the egg and slows it down without exerting a greater force than the egg's greatest allowable impulse.
Thanks!
I tried this with a cardboard box and it worked!
now i only have to find a way to make it be 5cm off the ground, so a smaller box, and a smaller box to fit into the target!
thanks for the idea, though!
Im going to use it, I threw it down as hard as i could, and it didnt crack. Same with throwing it down off of my 2nd story roof. Thank god for my moms stockings!
:smile:
Fantastic!
How's the landing accuracy? Can you nail a 40cmx40cm square?
well, you that's the hard part...
i decided since it bounces away off the target, I put a cardboard box within the limits and will land it in there
I think you found the problem with elastic materials - bounce! A material that deforms would not have a bounce.
You could try using a high viscosity liquid like pancake syrup. You then may need to figure out the density - in water the egg would sink, meaning that only the bottom surface of the water would need to be 5cm from the ground. The syrup may or may not have a higher density so you may need to find something else. Your mom should love such experiments in the kitchen... :smile:
ya but any liquid or gas that is denser than H20 is considered padding! and that's -3 pts and that is an 85% already
i think that you would be hard pressed to find a gas , more dense than water.. :rolleyes:
noooo, really?
haha :smile:
Note that high viscosity doesn't necessarily mean high density.
Oil, for example, is more viscous and less dense than H2O.
hehe
onto the subject. surface tension might be able to break the egg on impact from the height you described.
Hmm how might you be able to minimize suface tension... in regards of water/ pancake batter/ etc.. :wink:
bubbles would break up the tension ? They use a big aeration grid under the local freestyle jumping pool so that when the skiier smacks down from 40+ ft there is less surface tension.
My first approach, me being me and all, would be to construct a liquid-core artificial egg out of a nice resilient polymer. Secondly, I would glue a guide tube to the side of the egg and drop it down a cable that widens at the base to provide a rapid yet gentle braking force with full-stop coming within a hair's-breadth of the floor. If you want to use the box approach, I would modify it to be a shape like an air-dropped bomb casing, with a significant 'crush zone' that would absorb the impact through some sort of honey-comb structure and then quietly fall over to put the egg closer to the ground.
By the way, it's great to see another Smokey admirerer. That guy is one of my idols in the field of circumventing the rules without breaking them.
This idea is a variant from Mythbusters.
Make a cone from paper(or funnel if you prefer), tape it together. Fill a latex glove(stronger than a balloon) and place it in the nose of the cone. Now, I don't know exactly how to do this without padding, but on the show they wrapped the egg in balloons, etc. to cusion it. Maybe you could put the egg in a balloon(no air), and than place that balloon in another filled with air in a way that the necks are attatched so the balloon with the egg is suspended. Than tape those inside the cone. Give it some weight in the nose, and presto!
10K
