Physics Suggestions - Over my user level
  • Context: High School
  • Thread starter Thread starter JeremyJohnson
    Physics Suggestions
The discussion revolves around a design challenge related to creating a rotating mechanism for a model frame of a six-sided cube. Participants explore potential methods for connecting and rotating the frame sections independently, with a focus on mechanical solutions and the use of motors.
  • Jeremy describes a design involving a cube frame where each section should rotate independently from a single axis base.
  • Some participants suggest using separate motors for each face or section of the cube, questioning the necessity of mechanical linkages.
  • One participant proposes making the dowels hollow to allow for internal motor placement, although this raises additional challenges.
  • Another participant mentions the possibility of using bevel gears to connect the dowels, noting that some edges would need to rotate in opposing directions.
  • Jeremy expresses uncertainty about visualizing motor placement and the feasibility of making the dowels hollow.
  • There is mention of a previous project involving a similar mechanism, which may provide insights but does not resolve the current design issues.
Participants do not reach a consensus on the best approach to achieve the desired rotation of the frame sections. Multiple competing views on the use of motors and mechanical linkages remain present throughout the discussion.
Participants acknowledge limitations in visualizing the design and the complexity of creating a functional mechanism. There are unresolved questions regarding the practicality of suggested solutions and the implications of different design choices.
Individuals interested in mechanical design, robotics, or hobby projects involving kinetic structures may find this discussion relevant.
JeremyJohnson
Hi Everyone,
Ok, I have been trying to find a solution to a design that I am working on. There is a practical application in physics but I need to solve this piece before moving forward.
This is a hobby project and the know-how to do this is above my user level.
Here is what I am trying to do:
1. I have a model frame outline of a 6 sided cube.
2. The axis base will be one of the corners.
3. I want a method (possibly gear based) at the axis base that rotates causing each section of the cube frame to rotate independently.
Here are my questions:
How do I connect this together ?
How do I get a gear system in place that can rotate from one point causing all other sections of the frame to rotate?
This design has not given me much peace since I envisioned it.
Any help would be greatly appreciated.
Thanks
Jeremy
JeremyJohnson said:
Hi Everyone,
Thanks
Jeremy
Welcome to the PF.
It's kind of hard to visualize what you are describing. Any chance you could post a sketch?
Can you just use 6 motors to rotate the 6 faces (or whatever)? Does it all have to be via mechanical linkages, or would separate motors do the trick?
Ok, here is a picture of what I am trying to solve as a basis for the rest of the project.
The frame is 10 inch long metal dowels.
There needs to be a base that this frame connects to (not necessarily the same size as the other frame sections as there will be another shape inside.)
I have no idea how to keep the frame portions connected and rotate independently.
Sorry for the poor image as it was done quickly in powerpoint just to give you a visual.
Thanks,
Jeremy
Thanks,
Jeremy
Do you mean you want each of the 6 dowels to be able to rotate independently (not each face of the cube)? You can make them hollow, and have them over a non-moving 6-sided frame. Then rotate each of the 6 outer dowels using 6 separate electric motors (which you can hide inside the frame pieces).
Thanks for the suggestion. However, getting the metal dowels to be hollow would present another issue altogether. I cannot visualize the motor placement that you suggest. I really do not have a preference as to how this should work. Each segment of frame should rotate (spin) and the entire piece should rotate on the base.
If it is indeed the dowel/edges that you want rotating along their long axis you pretty much have no choice but to make them tubes and run a supporting axle structure inside them. I did a similar thing with a simple triangle: http://www.etantdonnes.com/KINETIC/fear_head.jpg although you may not be able to tell much about the mechanism from the photo... (There's a short movie linked off of http://www.etantdonnes.com/kin_summer07.html that might, or not, help).Coming up with a driving mechanism that works from a single motor might be over your pay grade as well. I can imagine, but not entirely picture, bevel gears on the ends of each dowel that connect to others' ends to translate motion. Some edges would have to spin in opposing directions, which may not be an issue for you. Otherwise use six small motors mounted in the corners somehow. For my piece the axles are also hollow tubes and I ran the wiring through them.
Good luck Mr Phelps.
Thanks for the great insight.
This is the easy one. You should see the plans I have drawn up for a laser microsonic projectile.
Getting dowels to spin and hold that shape is hard now. The rest of that design & components as well as this next project will keep me busy for a bit.
Although, my interest in these things did not occur until late in life and within the last few years.
Jeremy
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 60 ·
  • · Replies 29 ·
  • · Replies 17 ·
