Physics Wordy Question: Calculating Areas and Masses on a Graph - Help Needed!
  • Thread starter Thread starter farhana21
    Physics
The discussion revolves around a physics problem involving the calculation of areas and masses based on a graph. Participants are seeking assistance with specific parts of the problem, particularly in calculating a percentage and determining the slope of a line derived from experimental data. The scope includes mathematical reasoning and conceptual clarification related to the problem.
  • Homework-related
  • One participant requests help with parts (b) and (c) of a physics question involving a graph, noting that their previous attempt at part (b) yielded 1.5%.
  • Another participant suggests a method for calculating a percentage, emphasizing the need to identify the correct base value for the percentage calculation.
  • A different participant provides a specific answer for part (c) as 0.00052 g/cm³ and expresses frustration over being stuck on part (b).
  • Some participants discuss the calculation of the slope, with one noting the importance of selecting appropriate points on the graph and providing the formula for slope calculation.
  • There are mentions of potential errors in units and the relationship between the calculations for parts (a), (b), and (c).
  • One participant highlights the possibility of statistical or systematic errors affecting the slope and the implications of the line not passing through the origin.
Participants express differing views on the calculations for parts (b) and (c), with no consensus reached on the correct answers. Some participants challenge each other's methods and results without resolving the disagreements.
There are unresolved issues regarding the assumptions made in the calculations, particularly concerning the base value for percentage calculations and the implications of the slope not passing through the origin.
farhana21
Can someone please help me on this question please.
A student is supplied with a stack of copy paper, ruler, compass, scissors, and a sensitive balance. He cuts out various shapes in various sizes, calculates their areas, measures their masses and prepares the graph in the figure below.
(a) Consider the fourth experimental point from the top. How far is it from the best-fit straight line? Express your answer as a difference in vertical-axis coordinate.
The answer for part a is 0.015g
(b) Express your answer as a percentage.
(c) Calculate the slope of the line.
I need help on part b and c of this question.
The answer for part b is not 1.5% i already tried this.
I have attached a graph for you all to look at.
Thanks for the help and assistance in advance.
Its much appreciated
(b) You don't know how to work out a percentage?
- you have to say what you tried!
The trick is to figure out what the number is supposed to be a percentage of.
Divide the number by what it is supposed to be a percentage of, then multiply the result by 100.
if the value is y and the deviation is Δy, then "Δy is 100*Δy/y percent of the value".
(c) to work out the slope of the line, find the coordinates of two points on the line (any two that are not data points: read them off the graph). The equation of the line that goes through both of them is y=mx+c, m is the slope. m=Δy/Δx
The answer for part c is The answer to part c is 0.00052 g/cm^3
would someone please kindly tell me the answer to part b.
im really stuck.
help is most appreciated
Thank you
Er... nope: that would be against the rules.
What is the difficulty with part (b)?
Check your working for part (c).
I cannot help you if you don't show me your working.
For part (c) I chose a grid point on the line far from the origin: slope = 0.31 g/600 cm2 = 0.000 52
For part (b) I did (200, 0.1) (300, 0.15).
Then (0.15-0.1)/(300-200) = 5* 10^-4 * 100 *100 = 5%
Ok, but your units are wrong.
How is that related to (a)? You should give the absolute deviation calculated in (a) (0.015g) as relative deviation.
I would add:
That looks like the slope of a line between the two points names expressed as a percentage. What were you are asked to find again?
For part (c) I chose a grid point on the line far from the origin: slope = 0.31 g/600 cm2 = 0.000 52[units?]
... that works provided the line passes through (0,0) - it aught to, since zero area implies no material - assuming that nothing unanticipated is going on.
Statistical or systematic errors could lead the actual data to produce a line that does not go through zero. Taking the slope through two points would reveal this.
Some courses like students to fudge results like this though.
  • · Replies 18 ·
  • · Replies 46 ·
15K
