Piecewise Function: Intervals of Increase/Decrease & Extremes/Asymptotes
The function is strictly increasing on the intervals (-∞, 0) and (0, ∞), but not on the interval [-1, 1]. It has a global maximum at f(0) = 1, while being bounded from above without any extreme points. There is a horizontal asymptote at y = 0 and an oblique asymptote with a slope of 1/2, represented by the line y = (1/2)x + 1. The discussion highlights the importance of checking continuity and understanding the behavior of the function at critical points. Overall, the function's characteristics are clarified through derivative analysis and graphical interpretation.
Kolika28
##f(x)=\left\{
\begin{array}{ll}
\frac{e^{-x}-1}{x}, & x>0 \\
\frac{x}{2}+1, & x\leq 0 \\
\end{array}
\right.##
a) At which intervals are f strictly increasing and at what intervals are f strictly decreasing.
b) Determine any local and global extreme values for f.
c) Determines if f has asymptotes.
The derivative
Should I just find the derivative of both of the functions? If so, I get that the function is increasing at the intervals (−∞,0) and (0,∞). Is this right, or can I just say that the function is increasing at the interval (−∞,∞)?
When graphing the function I don't see any local or global extreme values. f(x) consists of a straight line and curve with where f(x)=0 is not true. The whole function is not bounded, so I can't look at the values in the endpoints. But my teacher says there are extreme values. But how so?
I know there is at least one horisontal asymptote, y=0, given the first function. Because
I was told there is one oblique asymptote also. But how?
Likes Delta2
a) You would just say that the function is strictly increasing everywhere.
b) The function is bounded from above, but it has no extreme points. (It has a supremum, but no maximal value.)
c) what happens for large negative x?
b) Should I just say that it has a supremum then in x=0??
c) For large negative x I look at ##\frac{x}{2}+1##. And I just get ##-∞## . But that does not tell me what the oblique slope is?
Not on the interval [-1,1].
##f(0) = 1## is an absolute maximum.
Likes Delta2
Oops. I just assumed OP had checked for continuity at x=0...
No, it has a global max in x=0.
Kolika28 said:
c) For large negative x I look at x2+1x2+1\frac{x}{2}+1. And I just get −∞−∞-∞ . But that does not tell me what the oblique slope is?
You are not looking for a value of the function. You are looking for a line on the form ##kx+m## that the function approaches.
The slope of a line is constant, here =1/2.
Ok, now I understand what you mean by task b. But I'm still confussed about c). So I'm supposed to find a line on the form ##kx+m##.
Orodruin said:
You are not looking for a value of the function. You are looking for a line on the form kx+mkx+mkx+m that the function approaches.
So is the oblique tanget just ##\frac{x}{2}+1##?
Hmm, why not this interval. Is the function decreasing here?
Not in the entire interval, no. You have (correctly) concluded that the function is increasing on (-infinity,0) and (0,infty). What is left to check?
I'm sorry, but I'm really blank right now. I don't see what's left to check. Sorry, for all the questions by the way, I just really want to understand!
What is the value of f(0)? What is the value of f(0.000000001)?
Likes Kolika28
Ohh, I understand now. Thank you so much!My last question is:
Kolika28 said:
So is the oblique tanget just x2+1x2+1\frac{x}{2}+1?
