Piecewise Linear Programming with Multiple Functions
smehdi
Dear Friends
I have a question about linear programming. It would be great to have your comments or suggestions.
Consider the followings
\begin{equation}
Y = [y_{1}, y_{2}, \cdots, y_{n}]
G = [g_{1}, g_{2}, \cdots, g_{n}]
\textbf{X} =
\begin{pmatrix}
0 & x_{1,2} & \cdots & x_{1,n} \\
x_{2,1} & 0 & \cdots & x_{2,n} \\
\vdots & \vdots & \ddots & \vdots \\
x_{n,1} & x_{n,2} & \cdots & 0
\end{pmatrix}
\end{equation}
##\textbf{X}## is not symmetric. Here I show the ##i##th row of matrix ##\textbf{X}## by subscript ##(i,:)##, e.g., ##X_{(2,:)} = [x_{2,1}, 0, \cdots, x_{2,n}]## is the second row vector of matrix ##\textbf{X}## and subscript ##(:,i)## shows the ##i##th column vector.
The problem is
\begin{equation}
\begin{aligned}
& \min &Y = \sum_{j=1}^{n} y_{j}\\
& \text{subject to}
& X_{(i,:)} G^T \geq A \\
&& X_i \geq 0
\end{aligned}
\end{equation}
in which ##i## is fixed, say ##i=2##, matrix ##G## is known, elements of ##\textbf{X}## are also known except the ##i##th row and ##X_{(i,:)}## should be found. Each of the elements in ##Y_i## is a function of the column vector in ##\textbf{X}## of the same index , i.e.,
y_{j} = f(\textbf{X}(:,j))
I googled and found that the function ##f## that I am working with is a piecewise linear function! Actually here the problem is not to find the minimum of a piecewise linear function, but to find the minimum of sum over multiple piecewise linear functions!
Since I am totally new in the filed of linear programming I don't know how such a problem should be solved!
Does anybody have any comments or know some references about how I could solve this?
Thanks in advance.
What does ##X_i \geq 0## mean? It does not fit to the other notation.
As all but one element of X(:,j) is known, it is possible to introduce functions gj which cover those dependencies. Define ##Z=X_{i,:}## and ##Z_j=X_{i,j}##
$$\text{Maximize}~ Y = \sum_{j=1}^{n} g_j(Z_j)$$
with the constraint
$$\sum_{j=1}^{n} Z_j G_j \geq A$$
and maybe some other constraint I don't understand.
Depending on how ugly f is, a usual maximization algorithm could work.
with the constraint
Thank you mfb for your hint.
I meant ##x_{i,j} \geq 0##.
##f## is a convex increasing piecewise linear function. I think it is not ugly that much :)
Oh great, then I would expect a single minimum without additional local minima. Every minimization algorithm should find that. If f is not decreasing, your constraint on the sum should always lead to equality, which means you can directly include it in the parameter space (for example, let one of the unknowns be fixed by all others via this condition).
Likes smehdi
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
