Why is There a Factor of 2 in the PIV Rating for a Full-Wave Bridge Rectifier?
The factor of 2 in the Peak Inverse Voltage (PIV) rating for a full-wave bridge rectifier arises from the relationship between the transformer secondary voltage and the output voltage. Specifically, the PIV is defined as the peak line-to-line voltage, and this factor is relevant when considering the output voltage derived from one leg of the transformer in a center-tapped configuration. The confusion often stems from applying Kirchhoff's Voltage Law (KVL) incorrectly, as the output voltage is influenced by the conducting diode's connection to ground. For practical applications, a safety factor of 2 is commonly used in component ratings to ensure reliability.
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Familiarity with full-wave bridge rectifier circuits
  • Knowledge of transformer operation and turns ratio
  • Basic concepts of Peak Inverse Voltage (PIV)
  • Study the relationship between transformer turns ratio and output voltage in rectifier circuits
  • Learn about the implications of PIV ratings in power supply design
  • Explore the differences between center-tapped and full-wave bridge rectifiers
  • Investigate safety factors used in electronic component ratings
Electrical engineering students, circuit designers, and anyone involved in power electronics who seeks to understand the principles of rectification and voltage ratings in circuit design.
SuperCat
Part C of the problem below. I have the solution but I don't follow the logic.
Turns ratio: Vp/Vs = Np / Ns
KVL
I do not think I need any elaborate formulas to solve this.
Solution Provided by instructor:
I am confused why there is 2 in front of Vs.
When I apply KVL to a loop it looks something like:
Reverse Biased Diode = Forward Biased Diode + Vo
My KVL matches up with page 213 of Microelectronics Circuits Sedra 7e:
The solution provided to me seems like it would match up with a center-tapped full-wave rectifier, but I have asked a handful of classmates who all seem to agree with the provided solution so I was hoping to either receive confirmation that the solution provided to me is wrong or an elaboration.
Many thanks!
You are right.
You might pose this question to your instructor:
Since one end of the secondary is always connected to ground thru a conducting diode, and the only voltage source is the transformer secondary, where does the factor of 2 come from for the PIV rating?
P.S. The PIV is always the peak line-to-line voltage. The factor of 2 applies to full wave center tapped only in that the output voltage is derived from the voltage of one leg of the transformer, i.e. center tap to one end.
P.P.S. In the real world of making stuff that continues to work, a safety factor of 2 is used in almost all component ratings. I doubt that he has this in mind for this course on theory.
A rather old reference:
Reference Data for Engineers: Radio, Electronics, Computer, and Communications. Seventh Edition, 1985. Pg. 14-12. Howard W. Sams & Co. Indianapolis , Indiana, ISBN 0-672-21563-2
