Planar wave solution to zero potential Schrödinger equation
63 replies · 7K views
Schwarzschild90
\begin{align}
\begin{split}
\psi(x, t) = e^{(ikx- i \omega t)}
V(x) = 0
\end{split}
\end{align}
For a free particle, the Schrödinger equation can be put in the form of ##\psi(x, t) = e^{(ikx- i \omega t)}##. With constant potentials for all x, ##\forall x : V = 0##, or put equally succinctly: ##V(x) = 0## (the function of which is time independent for all x in the domain)
\begin{align}
\begin{split}
i \hbar \frac{\partial \psi}{\partial t} = -\frac{\hbar^2}{2m} \frac{\partial^2 \psi}{\partial x^2} + V \psi
\end{split}
\end{align}
Make the substitution ##\psi(x, t) = e^{i(kx-\omega t)}##
\begin{align}
\begin{split}
i \hbar \frac{\partial}{\partial t} e^{i(kx- \omega t)} = \frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2} e^{i(kx- \omega t)}
\end{split}
\end{align}
Now, take the partial derivative with respect to time of the left hand side of the equation
\begin{align}
\begin{split}
i \hbar \frac{\partial}{\partial t} e^{i(kx- \omega t)} = -i^2 \hbar \omega e^{(ikx-\omega t)}
\end{split}
\end{align}
And the second order partial derivative with respect to x, of the right hand side of the equation
\begin{align}
\begin{split}
\frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2} e^{i(kx- \omega t)} = \frac{\hbar^2}{2m} (i^2k^2) e^{i(kx- \omega t)}
\end{split}
\end{align}
Moderator's note: post edited to fix the LaTeX. Use double # for inline equations, not $.
You should get rid of the ##i^2##. Otherwise, do you have a question?
And (2) ##\Rightarrow ## (4) + (5) = 0 gives you ?
@BvU: A homogenous partial differential equation
@DrClaude: I imagined that I would simplify a little later
$$ a = b\\c = d $$ gives a pde ## a=c ##, I agree :wink:.
\begin{align}
\begin{split}
\frac{\hbar^2}{2m} (k^2) e^{i(kx- \omega t)} - \hbar \omega e^{(ikx-\omega t)} = 0
\frac{\hbar}{2m} (k^2) e^{i(kx- \omega t)} = \omega e^{(ikx-\omega t)}
\end{split}
\end{align}
And cancelling an $\hbar$ right away
Bingo !
-- kudos for using the \split goody. Didn't know it. But it seems to confuse the \align thingy, perhaps because of the label rhs appearing twice ...​
I see no reason not to cancel the following term
\begin{align}
\begin{split}
e^{i(kx- \omega t)}
\end{split}
\end{align}
but I've been wrong before :P
(6) has to be true for all t and all x, independently.
What is happening here is separation of the variables x and t.
Oh, and ##e^{iy} \ne 0 ## always, so why not ?
So for a free particle (in a box) we have
\begin{align}
\begin{split}
k^2 = \frac{p^2}{\hbar^2}
\end{split}
\end{align}
But the wavenumber
\begin{align}
\begin{split}
k = \frac{\pi}{\lambda} \\
\left( \frac{\pi}{\lambda} \right)^2 = \frac{p^2}{\hbar^2} \to \left( \frac{\pi}{\lambda} \right) = \frac{p}{\hbar}
\end{split}
\end{align}
\begin{align}
\begin{split}
\end{split}
\end{align}
Work with the equations ou already have. Don't introduce p here (which is an operator, since you are working in position space).
And wasn't ##k = {2\pi\over \lambda } ## :wink: ?
(But I agree with Claudius)
So I can use the following identity to separate variables
\begin{align}
\begin{split}
e^{iy} = \cos(y)+ i \sin(y)
\end{split}
\end{align}
And use the fact that
\begin{align}
\begin{split}
e^{i(kx- \omega t)} = e^{ikx} \times e^{- i \omega t}
\end{split}
\end{align}
Since e^(iy) \neq 0 always, I could go ahead and cancel the term on both sides of the equation?
All in favor !
Therefore k and omega need to be related in the following way
\begin{align}
\begin{split}
\frac{\hbar}{2m} k^2 = \omega(k)
\end{split}
\end{align}
Isn't it nice ? And if we now take a sneak preview: with ##E = \hbar\omega\ \ \& \ \ \vec p = \hbar \vec k\ \ ## it looks like ##E = {p^2\over 2 m}## :smile: !
It's a ridiculously satisfying result :))
Should I let the angular velocity depend on k?
Thanks :biggrin:
Which function do you think the author of exercise b asks me to use?
The one in (1).
You were already embarking on dissecting it in
\begin{align}
\begin{split}
\end{split}
\end{align}And use the fact that\begin{align}
\begin{split}
\end{split}
\end{align}
(and you remember that coefficients are complex numbers in QM)
That yields the following
\begin{align}
\begin{split}
e^{i(kx-\omega t)} = \cos{(i(kx-\omega t))} + i \sin{(i(kx-\omega t))} \\
Closest: \ cosh(k x-t \omega)-sinh(k x-t \omega)
\end{split}
\end{align}
Re:
This ##\omega## is a totally different angular velocity.
I have become quite enthousiastic about these Feynman lectures (the link came from Simon Bridge) -- Richard Feynman talks about photons, but later on you understand that this is true for all and everything (except radioactivity and gravity :smile: ).
Re:
\begin{align}
\begin{split}
\end{split}
\end{align}
I seem to remember something like ##e^{ix} = \cos x + i\sin x## :smile:
The linear combination resulting is then
\begin{align}
\begin{split}
e^{i(kx-\omega t)} = \cos{(kx-\omega t)} + i \sin{(kx-\omega t)}
\end{split}
\end{align}
I'm very fond of watching Feynman's lectures as a way to cover more ground and to develop insight in physics
\begin{align}
\begin{split}
\end{split}
\end{align}
So, as answer to b), you write ##\ \Psi_s = \ \ ## ?? and ##\ \Psi_c = \ \ ## ??
\begin{align}
\begin{split}
\Psi_c = \cos{(kx-\omega t)} \\
\Psi_s = i \sin{(kx-\omega t)}
\end{split}
\end{align}
I can't see how I get rid of the complex coefficient
There is no reason to want to get rid of the complex coefficient (they are just fine, see #22). Wave functions have complex values.
However, you have another problem on your hand: From Euler you have an expression for ##\cos x## and it doesn't just contain ##e^{ix}## but also ##e^{-ix}##. In other words: you need to check that ##\ \Psi = e^{-i(kx-\omega t)}\ ## also satisfies the Schroedinger equation (1.1) and then determine ##C_1## and ##C_2## in ##\ \Psi_s = \ \ C_1 e^{i(kx-\omega t)} + C_2 e^{-i(kx-\omega t)}## .
Idem ##\Psi_c##
Note that (7) can't be the answer: they are part of the problem statement for (b) !
\begin{align}
\begin{split}
-\omega = \frac{\hbar}{2m} k^2
\end{split}
\end{align}
Are we running into trouble here ?
