Schwarzschild90
- 111
- 1
I think the solution might just be antisymmetric: Equal in magnitude but opposite in sign.
All you need to do is to identify the coefficients. Of course, negative ##k## will also give a solution to the SE, but that is besides the point - you have been given two particular wave functions and need to express them in terms of the functions you have.Schwarzschild90 said:Yes, since we've found the dispersion relation.
\begin{align}
\begin{split}
\Psi = C_1 e^{i(kx-\omega t)} + C_2 e^{-i(kx-\omega t)} \to \\
e^{i(kx-\omega t)} = C_1 e^{i(kx-\omega t)} + C_2 e^{-i(kx-\omega t)}
\end{split}
\end{align}
vanhees71 said:Yes, and the correct time-dependent states are then ##\cos(k x) \exp[-\mathrm{i} E(k) t]## and ##\sin(k x) \exp[-\mathrm{i} E(k) t]##. These are the energy eigenstates in the Heisenberg picture of time evolution, by the way.
Problem should have said:(b) Write [itex]\Psi_s = e^{-iwt}\sin(kx)[/itex] and [itex]\Psi_c = e^{-iwt}\cos(kx)[/itex] as linear combinations of wavefunctions of the previous form.
vanhees71 said:the eigenstates (e.g., the position eigenstates) are time dependent) according to
$$|x,t \rangle_{\text{H}}=\exp[\mathrm{i} \hat{H} (t-t_0)] |x,t_0 \rangle_{\text{H}}.$$
vanhees71 said:the correct time-dependent states are then ##\cos(k x) \exp[-\mathrm{i} E(k) t]## and ##\sin(k x) \exp[-\mathrm{i} E(k) t]##. These are the energy eigenstates in the Heisenberg picture of time evolution, by the way.
