Saturated Solution Concentrations and Osmotic Pressure Calculations
  • Thread starter Thread starter kateman
The discussion focuses on three chemistry questions regarding saturated solution concentrations and osmotic pressure calculations. The first question involves calculating the millimolar concentration of a theoretical salt, with the participant expressing uncertainty about the relationship between the concentrations of X and Y. The second question addresses the change in entropy for a reaction, with the participant questioning their calculated value. The third question pertains to determining the osmotic pressure of a solution, where the participant is unsure about the units of their final answer. Overall, the thread seeks validation and corrections on the calculations presented.
kateman
There are 3 questions below with my working and answers, could someone please check that I am right, even if you can only give approval or correction on just one question and nothing else - anything would be appreciated. Please forgive my not following the template, as I didn't think it would work with checking correct answers. Thanks for any responces!
Q1: A theoretical salt (X2Y3) (with Ksp= 6.26 x 10 -15 ) is in a saturated solution. What is its millimolar concentration (mM) of X?
A1: Ksp= [X]2 [Y]3 = 6.26 x 10 -15
therefore concentration of Y = 3/2 concentration of X (or is it 2/3, iam not sure?)
therefore rewrite Y as [3/2 X]3
therefore Ksp= [X]2x 27/8 X3
= 27/8 [X]5
therefore, with rearranging, [M] = 1.131514468x10-3 mol/L
= 1.131514468 mM/L
Q2: A reaction at temperature of 287K gives a change in enthaply of -7KJ and a free energy change of -10kJ, what is the change in entropy for this reaction (in J/K)?
A2: \DeltaG = \DeltaH - T\DeltaS
with rearranging: \DeltaS = \DeltaH - \DeltaG / T
=(-7 - -10)/287 = 0.010452961 J/K
That doesn't seem right to me.
Q3: If a 0.5 L solution at a temperature of 294.75 K contains 13.7g of an unknown solute (with a molecular mass of 60.094g), what is its osmotic pressure in atmospheres?
A3: since moles (n) = concentration (c)/ volume (v) = mass (m)/ molecular weight (M)
then C = m/Mv = 13.7 / (60.094x0.5) = 0.455952341 mol/L
Now use the values of C, T and the gas constant (8.314 J/mol K) into the osmotic pressure formula P=CRT
P= 0.455952341x8.314x294.75 = 1117.334694 Pa (am I right to say that its in pascals, or is it in killapascals [Kpa]?)
atmospheres = 101.325 Kpa = 101325 Pa
osmotic pressure (in atmospheres) = 1117.334694/101325 = 0.011027236 atms
This is something iam really not sure about, the answer seems almost wrong to me but iam not sure where I would have gone wrong in my working, can someone please help? It would be very much appreciated!
Thank you!
You use too many significant digits every time.
First looks OK.
Second and third - approach seems correct (even if in the second your formula misses parantheses), but second opinion won't hurt.
Thank you Borek, and I agree, I'd still appreciate at least another person's opinion on my working.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
