Please check this complex integral (#2)
The integral evaluation of \( \oint \frac{e^{iz}}{z^3}dz \) over a square contour centered at 0 reveals a simple pole of order 3 at \( z = 0 \). The correct approach utilizes the Cauchy Integral formula, leading to the conclusion that the integral equals \( -\pi i \). The error in the initial attempt was taking an extra derivative when applying the formula. The power series expansion of \( \frac{e^{iz}}{z^3} \) confirms that the coefficient of \( z^{-1} \) is \( -\frac{1}{2} \), resulting in the final answer of \( -\pi i \).
  • Complex analysis fundamentals
  • Cauchy Integral formula
  • Residue theorem
  • Power series expansion
  • Study the Cauchy Integral formula in depth
  • Learn about the residue theorem and its applications
  • Explore power series expansions of complex functions
  • Practice evaluating integrals with singularities
Mathematics students, particularly those studying complex analysis, and professionals involved in theoretical physics or engineering requiring integral evaluations.
ognik
An old exam question is: Evaluate $ \oint \frac{e^{iz}}{z^3}dz $ where the contour is a square of sides a, centered at 0. This has a simple pole of order 3 at z = 0
Perhaps using residues, $ Res(f,0) = \frac{1}{2!}\lim_{{z}\to{0}}\d{^2{}}{{z}^2}z^2 \frac{e^{iz}}{z^3} = \frac{1}{2}\lim_{{z}\to{0}} \d{^2{}}{{z}^2}\frac{e^{iz}}{z} $
But this will have z to some power in the denominator, with z -> 0, so I don't think I can do that
Instead I'll try the Cauchy Integral formula, $ \oint \frac{e^{iz}}{z^3}dz = \frac{2 \pi i}{2!}f^{(3)}(0) $, with $f(z) = e^{iz}$
$f(z) = e^{iz}, f^{(3)}(z)=-ie^{iz}, f^{(3)}(0) = -i$ and $ \oint \frac{e^{iz}}{z^3}dz = \pi $
Is all this correct please?
This is wrong. You took an extra derivative.
You can also write $\frac{e^{iz}}{z^3}$ as a power series and notice the only term with $z^{-1}$ in it has coefficient equal to $\frac{(iz)^2}{(2!)z^3} = -\frac{1}{2z}$
When you integrate $z^{-1}$ over that region you get $2\pi i$. Therefore, the final answer will be,
$$ 2\pi i \times -\frac{1}{2} = -\pi i$$
All clear, thanks for the series suggestion as well.
