Please explain volume of parallelepiped
  • Thread starter Thread starter maff is tuff
    Explain Volume
The volume of a parallelepiped can be expressed as V = |b cross c||a||cos(theta)|, which represents the area of the base formed by vectors b and c multiplied by the height determined by vector a. The transition to the expression |a dot (b cross c)| is based on the property of the dot product, where |A dot B| = |A||B|cos(theta), with theta being the angle between vectors a and (b cross c). This means that the height of the parallelepiped, represented by |a|cos(theta), is effectively captured in the dot product with the cross product of b and c. Thus, both expressions for volume are equivalent, confirming the relationship between the geometric interpretation and the algebraic formulation. Understanding this connection clarifies how the volume can be calculated using either method.
maff is tuff
Ok so my book says that the volume of a parallelepiped is:
V= |b cross c||a||cos(theta)| = |a dot (b cross c)|, where a, b, and c are vectors
I get the "|b cross c||a||cos(theta)|" part because I can see the geometry but I don't get how they get from that to |a dot (b cross c)|.
I see how |a||cos(theta)| looks kinda familiar so I tried to figure out using that.
So I know a dot b = |a||b|cos(theta), so
|a|cos(theta) = (a dot b)/|b| but then if I plug that quantity in it doesn't seem to work.
So can anyone help me see why |b cross c||a||cos(theta)| = |a dot (b cross c)| ?
Think of a, b, and c with their tails together. b x c is a vector perpendicular to the plane of b and c and |b x c| is numerically equal to the area of the parallelogram formed by b and c. To get the volume of the parallelepiped formed with this parallelogram as a base and a as the third side you need to multiply the area of the base by the height of the parallelepiped. But the height of the parallelepiped is the component of a perpendicular to the plane of b and c. If theta is the angle between b x c and a, then this height is h = |a|cos(theta). So the volume is V = h|bxc| = |a|cos(theta)|bxc| = a dot (bxc). Does that help?
I already understood how the volume is |bxc||a||cos(theta)| but I don't understand how that equals |a dot(bxc)|. Can you explain how |bxc||a||cos(theta)|= |a dot(bxc)|? Thanks.
Oh, that's all you are asking. That is just the basic property of dot product:
\vec A \cdot \vec B = |\vec A||\vec B|\cos\theta
applied to a and bxc. Here θ is the angle between a and bxc.
Ok so I'm still not seeing it.
I want to show that |bxc||a||cos(theta)| = |a dot (bxc)|
ok my first step: I know that a dot b = |a||b|cos(theta) so I can solve for |a|cos(theta)
So now I have |bxc|(a dot b)/||b| = |a dot (bxc)|
So I plug it in and get:
|bxc|[(a dot b)/|b|] and now I am stuck.
Just do what I suggested above. Replace B by BxC in the identity.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
