Undergrad How Accurate is Propositional Logic in Explaining Multiple Integrals?
The discussion centers on the use of propositional logic to interpret concepts from Tom M. Apostol's "CALCULUS VOL II," specifically regarding the definition of step functions. The original poster finds the logic-based approach easier for comprehension than the text-heavy format of the book, despite others arguing that Apostol's explanations, which include verbal descriptions and illustrations, are clearer. Participants express concern that the logic format may obscure understanding rather than enhance it, suggesting that visual aids and textual explanations are crucial for grasping complex mathematical concepts. There is a debate about the effectiveness of using logical language versus traditional English descriptions in mathematics. Overall, the conversation highlights the challenges of translating mathematical definitions into propositional logic while maintaining clarity.
oliverkahn
TL;DR
Can anyone point out the mistakes or incorrect logical steps (if any) in the attached PDF file.
The following 3 pages are extract from the book: "CALCULUS VOL II" by Tom M. Apostol
My interpretation of these 3 pages is worked out in the attached PDF file. Entirely done in propositional logic language.
  • Wow
Likes PeroK
Why would you want to do this? It's almost as if you had taken something that is fairly straightforward, and encrypted it.
I need to do this because I am having difficulties in quickly comprehending that book. The encrypted one is much more easier for me to make sense of what the book is saying. Also the book has skipped several trivial proofs.
And I'm having extreme difficulties in understanding what you have done. Apostol's book, like many advanced mathematics books, is not intended for quick comprehension. However, it includes text descriptions of what it's describing, as well as images, neither of which is present in your work.
Rather than coming up with something that is nearly incomprehensible, I think it would be better to ask questions about the parts of Apostol's explanation that you don't understand.
If the proofs are indeed trivial, it shouldn't be a problem that they have been skipped. Calculus textbooks often do this sort of thing.
In the first page of my work, I guess everything MAY be comprehensible except the last biconditional...
In the book, it is written as:
This is equivalent to the following statement:
DEFINITION OF STEP FUNCTION: A function ##f## defined on a rectangle ##Q## is said to be a step function if(f) a partition ##P## of ##Q## exists such that on each of the open subrectangles of ##P##, ##f## is constant. A step function also has well defined value at each points of the partition boundary.
This statement can also be written in logic language as:
##f: Q \longrightarrow \mathbb{R} = \text{step function}##
##\Leftrightarrow##
##\exists\ P \ni##
##\forall\ Q_{ij}, \left( f: Q_{ij} \longrightarrow \mathbb{R} \right)= \text{a constant AND } f:\text{partition boundary} \longrightarrow \mathbb{R}##
Hope this may be comprehensible. (or not?). If yes, everything in the first page of my work may be easy to understand.
I have not used English text in my work because through logic codes, it is much easier for me to visualize what the symbols are trying to tell us rather than English text filled with grammers. This is my personal opinion. Others may be having different opinions.
In fact, your version is nearly identical to the one in Apostol.
##\Leftrightarrow##
##\exists\ P \ni##
Yes, I understand this, but IMO it is not as good as Apostol's definition, because Apostol explains the definition in words, and includes drawings of what the partition might look like.
It is much easier for most people to visualize something if there is a drawing. If it works for you, then fine, but most native speakers of English (which I assume from your IP address) would have a better grasp with a description in English plus a drawing or two.
What you're doing seems to me to be something like describing the Mona Lisa painting via a Fortran program. Admittedly this is a rough analogy, but is something that came to mind.
Notice that since f is already defined on the whole rectangle, it is certainly also defined on the boundaries of the partition.
I do almost have some sympathy for some of your concerns about logical language, in particular the desire to precede a statement about some quantity with a quantifier specifying that quantity. I.e. it is indeed more precise and correct to say " for each sub rectangle Q, f is constant on Q", than to say "f is constant on Q, for each sub rectangle Q". Of course this is not quite what was said, and what was said is already pretty precise for normal English.
I myself used to have such overly strict obsessions with logical language. I am also sympathetic with those concerned about the value of rendering something understandable into something less so.
Likes oliverkahn
What do you mean by "rendering something understandable into something less so"
perhaps i should have said, that they consider less so, since i was only channeling some of the responses you have received. However, although i have not read your version, i recall people thinking my own propositional logic statements were less clear than the same thing said in normal English.
  • Sticky
  • · Replies 0 ·
