Please help me. topic: ( motion with constant acceleration : free fall )
The discussion revolves around a problem in motion with constant acceleration, specifically free fall. The scenario involves a can being dropped from a scaffolding that is rising at a constant speed, and participants are tasked with determining the time it takes for the can to reach the ground and its final velocity.
  • Mixed
  • Participants discuss the appropriate use of equations related to free fall and question the sign convention for acceleration due to gravity. There are attempts to clarify the initial conditions and the values to be used in the equations.
The conversation includes various interpretations of the problem setup and the formulas to be used. Some participants express confusion regarding the sign of gravity and whether to disregard the illustration provided by the professor. There is an ongoing exploration of how to approach the calculations without reaching a definitive consensus.
Participants note that the professor's illustration may be intended to aid understanding, but there is uncertainty about its relevance to the calculations. The discussion also highlights the importance of correctly applying the formulas based on the initial conditions provided in the problem.
donniemsb_12
A scaffolding is rising at 1.0 m/s when at a height of 50.0 m , then the man on the scaffolding drop a can. determine:
a. the time needed for the can to reach the ground .
b. what is the final velocity ?
note: g=-9.8 m/s
the letter o in the equation stands for initial example : Vo( initial velocity) .
V=Vo +(-g)t
y=yo + volt + 1/2(-g)T^2
V^2=Vo^2 + 2(-g)(y-yo)
y-yo=(v+vo)/2 (t)
t = time
y=position
v = velocity
g=gravity
The illustration was illustrated by our professor .
the attempt that i was trying to solve is i tried to get each of all the final velocity.
guys can you help me on how to solve this ! thank you !
donniemsb_12 said:
note: g=-9.8 m/s
That's confusing. I assume you mean that a = -g, where g = 9.8 m/s^2.
Use this formula to solve for the time.
sir yes ! a= g . and the g is equals to -9.8 m/s^2
sir ! how many times should i compute for the time ? is it 1 time or 4 times ? base on the illustration ?
If you insist on g being negative, then your formula is incorrect. (It has a -g in it.)
Why not just once? Solve for the final time when it hits the ground. What values will you put for y, y0, and v0?
sir ! our professor says that it is always negative . so he is wrong ? and the right is -g=9.8 m/s^2 ? right ? thank you ! so sir we will disregards the illustration ?? and compute the final velocity just once ?
Taking up as positive, the acceleration is -9.8 m/s^2.
(The constant g is usually taken as positive, so the acceleration would be -g.)
ah i see sir ! thank you. sir so i will disregard the illustration that our prof was made ? and i will focus in solving using the given value's in the problem ?
I suppose the illustration is there to help you visualize what's going on. (I think the velocity at point 3 should be negative.) But you can solve for the final time in one step, you don't need to solve for all the intermediate points.
so sir. i will be focus on the formula that u was given to me ?
Yes.
Doc Al said:
Yes.
t^2=-2(y)/g
t^2=2(50)/9.8
t=3.19 s
y-50=v^2-(1.0)^2/2(9.8)
v^2-(1.0)^2 = (-50)*2(9.8)
v^2-1 =-980
V^2/-1=-980/-1
v^2=980
V=31.30 m/s
sir am i right ? regards on solving the problem ? thank you !
donniemsb_12 said:
t^2=-2(y)/g
t^2=2(50)/9.8
t=3.19 s
:confused: Why didn't you use the formula I indicated in post #2?
sir i derived the formula that you indicate like what i saw in my lecture .
You posted some formulas. I quoted one and said "use this one". So use it. (The one you derived assumes that the initial speed is zero.)
