How Can You Safely Discharge High-Voltage Capacitors Without Losing Energy?
The discussion centers on safely discharging a capacitor bank consisting of two 470µF 400V capacitors in parallel without energy loss at the switch. The user initially attempted to use a MOSFET switch rated for 600V and 100A, which failed due to high current causing damage. Suggestions included using an inductive load in the discharge circuit to prevent arcing at the switch contacts and incorporating a damping diode and a high-wattage resistor for better control and troubleshooting. The importance of using capacitors designed for rapid discharge was also emphasized.
  • Understanding of high-voltage capacitor behavior
  • Familiarity with MOSFET specifications and limitations
  • Knowledge of inductive loads and their role in electrical circuits
  • Experience with circuit design involving damping diodes
  • Research the specifications and applications of high-energy discharge capacitors
  • Learn about the design and implementation of inductive loads in discharge circuits
  • Study the use of damping diodes in preventing oscillations in high-voltage circuits
  • Explore the role of high-wattage resistors in circuit troubleshooting and energy management
Electrical engineers, hobbyists working with high-voltage circuits, and anyone involved in capacitor discharge applications will benefit from this discussion.
gustafangus
Hello,
I have a bit of a problem with my project and it is as follows: I am trying to discharge a capacitor bank (2x 470uf 400V capacitors in parallel). I tried making a MOSFET switch to use that as a switch, but it kept burning out the mosfets (they were rated for 600V and around 100A), then I went and grabbed a laundry style clip (the plastic thing you use to hang clothes) and made a switch from that, HOWEVER, here is the problem. When I close the switch, there is always an explosion on the contacts of the switch (they become black aswell). I guess it's because the current is so high it just explodes on contact or something, i don't know. After these explosions, the capacitors are completely empty (they go from 400V to 0V), so the problem I have is that all the energy stored in the capacitors is discharged on that switch explosion, and I am wondering what kind of switching device or circuit or whatever I can make for there to be NO loss in energy on the actual switch, so I can actually use the energy stored in the capacitors for my project.
Thanks!
Why are the capacitors charged in the first place? It sounds like you are dealing with voltages and energies higher than you should be. Why not just use a large value resistance bleed resistor?
I'm not sure you understand, I am charging them with a DC power supply and trying to quickly discharge them on something. I know how to deal with high voltages, I have been doing this for a long time. My question was how to large capacitors with no energy loss on the switch. :)
Are you using capacitors specifically made for quick discharge of high energy? If you are using standard caps, there is a good chance they will be damaged by a rapid discharge.
What reading have you done on this so far? I did a quick Google search of high energy capacitor discharge, and got lots of good hits.
Put a inductive load in the discharge circuit. A suitable inductive resistance will prevent the switch contact arcing, as it opposes the discharge current surge.
To prevent oscillation, remember to also include a dampening diode parallel to the inductor.
And, just my personal preference, in such circuits, I include a one ohm, high wattage, inductively neutral resistor in the discharge path.
Among other things, it makes a handy test point for troubleshooting.
My question would be what other components are in the discharge circuit? So far we know about capacitors and a makeshift switch. Exactly where do you want this energy to go?
Thread locked for moderation.
  • · Replies 19 ·
  • · Replies 49 ·
  • · Replies 28 ·
15K
  • · Replies 19 ·
