Plotting Charge Density in 3D: Can My Data Be Formatted as an XYZ File?
Charge density data formatted as x, y, z coordinates with density values cannot be directly converted to an XYZ file, as XYZ files typically represent atomic positions rather than continuous charge density. The user is seeking to plot this data in 3D using gopenmol, which requires plt format. Alternatives like xcrysden or VESTA are suggested for visualizing charge density. Converting the current format to plt might be necessary before plotting. Exploring these alternative software options could provide a more suitable solution for 3D charge density visualization.
Morberticus
I have a charge density I would like to plot in 3D
The data is currently in the format
x1 y1 z1 density
x2 y2 z2 density
etc
etc
where x,y,z are grid points. Can this kind of data be formatted as an xyz file? I know xyz is normally atom locations (I have no explicit atoms), but I have heard it can be done.
The program I am using to plot it is gopenmol, which expects plt format. I can convert xyz to plt but not sure how to convert my data to xyz
Thanks
It doesn't sound like it. It sounds to me like an xyz file represents a different kind of data. I'd suggest looking at xcrysden or vesta for plotting charge density in 3D.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 16 ·
