PNP Transistor - Amateur Question
  • Thread starter Thread starter carlodelmundo
    Amateur Transistor
The discussion centers on the operation of PNP transistors, specifically how voltage applied to the base affects current flow between the emitter and collector. When no voltage is applied to the base, current flows freely from the emitter to the collector. However, when a voltage is applied to the base, even minimally, it allows current to flow, indicating the necessity of a base resistor to complete the circuit. The key takeaway is that for PNP transistors, the base must be at a lower voltage than the emitter to enable current flow.
  • Understanding of PNP transistor operation
  • Basic knowledge of circuit components (resistors, diodes, LEDs)
  • Familiarity with voltage and current concepts
  • Experience with circuit wiring and schematic interpretation
  • Study the role of base resistors in transistor circuits
  • Learn about NPN vs. PNP transistor characteristics
  • Explore transistor switching applications in circuits
  • Investigate common circuit configurations using PNP transistors
Electronics enthusiasts, amateur circuit designers, and students learning about transistor functionality and circuit design will benefit from this discussion.
carlodelmundo
I understand that when we apply voltage to the Base of the PNP Transistor (Emitter, Base, Collector), we actually block current from passing from Emitter to Current.
If there is no voltage applied to base, then current flows freely.
If this is the case... how come when I wire the following:
1.) + terminal of battery to
2.) diode (pointing towards +) to
3.) "Emitter" of PNP Transistor
4.) The "collector" of PNP transistor goes to
5.) - terminal of battery.
I get no closed circuit? (by the way, there's a resistor and LED between 4 and 5). However, when a voltage is applied to the base (even the slightest), the current is open?
The missing component is the base resistor.
Even though this is connected to ground, it supplies current to the base of the transistor to turn on the collector-emitter current.
PNP transistors are exactly the same as NPN transistors, except that the polaraity is reversed.
So, if it helps, just rotate the circuit so that the collector is at the top. You can now see the importance of having a base resistor and where it has to go.
Yes, basically in pnp transistors, you have to let current out of the base to turn on the transistor. This occurs when the base voltage is lower than the emitter voltage.
10K
