Point of application of magnetic torque.
The discussion centers on the application of magnetic torque on a current-carrying loop in a uniform magnetic field. It is established that when the magnetic field is uniform, the resultant force is zero, resulting in pure torque that acts about the center of mass or a constrained axis. The magnetic torque is independent of the chosen axis, similar to a mechanical couple, meaning it remains the same regardless of the reference point. This principle is illustrated through an example involving a sphere with a ring, where magnetic torque can be equated to gravitational torque at different points. Overall, the magnetic torque behaves as a free vector, consistent across various reference points.
anmol21
Hello,
When a current carrying loop (of any shape) is placed in a uniform magnetic field B , the field is given by MχB where M is the magnetic moment vector I*A where I Is current and A is the area vector. I want to know at which point or for which axis is the torque applied given by the above equation.
ζ=MχB
M=I*A
welcome to pf!
hi anmol21! welcome to pf! :smile:
if B is uniform, the resultant force will be zero, so the effect is a pure torque
so the circuit will turn about the centre of mass of whatever the circuit is fixed to (or about whatever axis that is constrained to turn around)
Thanks tiny-tim :)
So is the magnetic torque independent of the axis chosen ?
For example , Consider a sphere with a ring attached to it , with current I in the ring , in rotational equilibrium on a rough inclined plane. The magnetic field is vertically downwards and gravity is present. So we can equate the torque due to gravity and the magnetic torque at any point . So will be the magnetic torque be same even at the point of contact of the sphere with the ground or the centre of the sphere ?
hi anmol21! :smile:
the magnetic torque of a uniform magnetic field on a circuit is a couple
it is exactly the same as a couple (or "pure moment") in mechanics: it has the same moment about any point
"a system of forces with a resultant (a.k.a. net, or sum) moment but no resultant force"
"… the moment (torque) of a couple is independent of the reference point P: Any point will give the same moment. In other words, a torque vector, unlike any other moment vector, is a "free vector"."​
both quotes from http://en.wikipedia.org/wiki/Couple_(mechanics) :wink:
thanks a lot , that clears it up :)
