Polar coordinates of the centroid of a uniform sector
The discussion revolves around calculating the centroid of a uniform sector using both Cartesian and polar coordinates. Participants explore the differences in results obtained from each coordinate system and question the validity of their calculations.
  • Mixed
  • Participants discuss the calculations for the centroid's coordinates in both Cartesian and polar forms, noting discrepancies in the results. Questions arise regarding the interpretation of polar coordinates and the treatment of the radius as a vector versus a scalar.
Some participants have provided insights into the nature of centroids in polar coordinates and the necessity of expressing polar basis vectors in Cartesian terms. There is acknowledgment of errors in understanding the calculations, but no consensus has been reached on the implications of these findings.
Participants are navigating the complexities of integrating in polar coordinates and the assumptions made about the nature of the radius in these calculations. The discussion reflects on the geometric properties of the sector and the relationship between the centroid and the angle bisector.
parsesnip
Find the centre of mass of a uniform sector of radius a and angle θ.
##A=\frac{1}{2}a^2\theta##
Average value of value of ##f## over ##A=\frac{1}{A}\iint f\, dA##
If I use cartesian co-ordinates, I get:
##\bar{x}=\frac{1}{A}\iint x\, dA=\frac{1}{A} \iint r^2\cos\theta\, dr\, d\theta= \frac{2a\sin\theta}{3\theta}##
##\bar{y}=\frac{1}{A}\iint y\, dA=\frac{1}{A}\iint r^2\sin\theta\, dr\, d\theta= \frac{2a(1-\cos\theta)}{3\theta}##
But if I use polar co-ordinates, I get:
##\bar{r}=\frac{1}{A}\iint r\,dA=\frac{1}{A}\iint r^2\, dr\, d\theta=\frac{2a}{3}##
##\bar{\theta}=\frac{1}{A}\iint \theta\,dA=\frac{1}{A}\iint r\theta\, dr\, d\theta=\frac{\theta}{2}##
I believe the cartesian co-ordinates are correct and obviously the value of ##\bar{\theta}## is correct, but the polar co-ordinates of the centroid do not correspond with the cartesian co-ordinates. What is wrong with my calculation of ##\bar{r}##?
Centroids in non-cartesian coordinates don't work that way.
We are looking for [tex]\bar{\mathbf{r}} = \frac{\int_A \mathbf{r}\,dA }{\int_A\,dA}.[/tex] Now in cartesian coordinates you can do that by components easily: [itex]\mathbf{r} = x\mathbf{e}_x + y\mathbf{e}_y[/itex] and the basis vectors are constant, so [tex] \bar{\mathbf{r}} = \frac{\int_A x\,dA \mathbf{e}_x + \int_A y\,dA \mathbf{e}_y}{\int_A\,dA}.[/tex]
But in plane polars we have [itex]\mathbf{r} = r\mathbf{e}_r(\theta)[/itex], and in this case [tex] \bar{\mathbf{r}} = \frac{2}{a^2 \Theta} \int_0^a r^2\,dr \int_0^{\Theta} \mathbf{e}_r(\theta)\,d\theta[/tex]. To integrate [itex]\mathbf{e}_r(\theta)[/itex] you must first express it in terms of the constant cartesian basis: [tex] \mathbf{e}_r(\theta) = \cos \theta\,\mathbf{e}_x + \sin\theta\,\mathbf{e}_y[/tex] Once you have done that, you can find the polar coordinates of the centroid from [tex] \bar{r}^2 = \bar{x}^2 + \bar{y}^2 \qquad \tan{\bar\theta} = \frac{\bar y }{\bar x}.[/tex]
I agree with your results for [itex]\bar x[/itex] and [itex]\bar y[/itex], but as you've discovered [tex] \bar x \neq \frac{2a}{3} \cos (\Theta/2)\quad\mbox{and}\quad<br /> \bar y \neq \frac{2a}{3} \sin(\Theta/2).[/tex]
As it happens, [tex] \frac{\bar y}{\bar x} = \frac{1 - \cos \Theta}{\sin\Theta} = \frac{2 \sin^2 (\frac12\Theta)}{2\sin(\frac12\Theta)\cos(\frac12\Theta)} = \tan(\tfrac12\Theta)[/tex] but this is purely a coincidence.
Thank you so much for your answer! So I gather that my error was thinking of r as a scalar instead of a vector.
So does that mean that ##\frac{\iint r^2\,dr\,d\theta}{\iint_A dA}## is the average distance of a point in the sector from the origin, but the average displacement of a point in the sector from the origin (which is the displacement of the centrodi) is given by ##\frac{\iint r^{2}(\cos\theta \hat{i} + \sin\theta \hat {j})\,dr\,d\theta}{\iint_A dA}##?
Yes.
Not sure what you mean by that. Isn't it evident that the centroid will lie on the angle bisector?
  • · Replies 19 ·
