Population Dynamics: Logistic Model (Differential Equations)
KTiaam
Population Dynamics: Logistic model. Suppose the environmental carrying capacity of the population is 100000 and the growth rate a t=0 is 5%. . If the population starts at 10000, how long does it take for the population to reach half the carrying capacity?
dp/dt = A P (P1 – P), where P1 = 100 using 1000 as the unit of population. Here P'/P = 0.05 at t = 0.
Use P'/P = 0.05 and the value of P0 given above in the ODE P' = A P (P1 – P) to find A.
You have the solution of the ODE… use it to answer the question.
dp/dt = A P
p(t) = P0 ekt
P1 = 100
P(0) = 10
From my understanding you want to find P(t) = 50 and t = ?
I'm just having a hard time connecting dp/dt = AP and dp/dt = A P (P1 – P)
do i find what AP is and then set it equal to A P (P1 – P)?
or do i use p(t) = P0 ekt in some way.
It says "you have the solution of the ODE, use it to answer the question"
I am also not understanding what P'/P represents, as it is equal to .05, but that's the answer when i divide 50 by 1000.
Any help is appreciated.
KTiaam said:
dp/dt = A P
p(t) = P0 ekt
You have conlicting expressions for dP/dt. I believe the second is for the logistic model. The first is for a model that has no limit on carrying capacity.
You need to solve the logistic differential equation.
Could you explain a little bit more?
So use only p(t) = P0e^kt?
No, haruspex was talking about the logistic equation -- dP/dt = AP(P1 - P). This is the one you need to solve for P.
BTW, try to be consistent with the casing of your variables. Don't use dp/dt in one place and P on the other side. P represents population, so the equation should be as I wrote it above.
Yes, that's what I meant. But I just noticed in the OP it says "you have the solution to the equation". KTiaam, this implies you have already been given the solution to this differential equation, but you have not listed it. Instead, you have listed a simpler ODE and its solution.
Yeah, I was wondering about that, and didn't see the solution listed anywhere.
