Position Dependent Forces: Finding Velocity as a Function of Displacement
  • Thread starter Thread starter Speags
    Forces Position
The discussion focuses on deriving the velocity of a particle as a function of displacement under a position-dependent force, F(x) = Fo + Cx. The user starts with the equation of motion and applies the product rule to express acceleration in terms of velocity and displacement. After setting up the integrals for both sides, they encounter difficulties with the integration limits and the correct formulation of the integrals. The final derived equation shows that the velocity is given by v(x) = √((2Fo x + Cx²)/m), confirming the relationship between force, mass, and displacement. The thread concludes with a collaborative resolution of the integration problem and a warm exchange of thanks among participants.
Speags
the question asks,
Find the velocity v as a function of the displacement x for a particle of mass m, which starts from rest x=0
F(x)=Fo + Cx where Fo and C are positive constants
So far I've gotten,
ma=Fo + Cx
m (dv/dt)=Fo +Cx
m (dv/dx dx/dt)=Fo +Cx I split dv/dt using the product rule
m v dv=(Fo + Cx) dx v=dx/dt
now I'm haveing problems doing the intergal of both sides i have so far
m(v-vo)=?
can anyone help?
I've intergrated on the LHS from vo to v and i think the RHS should be from xo to x
What the problem?
mvdv=(F_{o} + C_{x})dx
\int_{v_{o}}^{v} mvdv= \int_{x_{o}}^{x} (F_{o} + Cx)dx
\int_{v_{o}}^{v} mvdv= \int_{x_{o}}^{x} F_{o}dx + \int_{x_{o}}^{x} Cxdx
Mass is a constant
Integrate.
m \int_{v_{o}}^{v} vdv= F_{o} \int_{x_{o}}^{x} dx + C \int_{x_{o}}^{x} xdx
You should have:
m \frac{1}{2}v^2]_{v_{o}}^{v}= F_{o}x]_{x_{o}}^{x}+ \frac{1}{2}Cx^2]_{x_{o}}^{x}
\frac{1}{2}m(v^2 - v_{o}^2)= F_{o}(x-x_{o})+ \frac{1}{2}C(x^2-x_{o}^2)
Our Particle starts from rest (Vo = 0) at x = 0 so
We got
\frac{1}{2}m(v^2)= F_{o}x+ \frac{1}{2}Cx^2
v(x) = \sqrt{\frac{2F_{o}x+ Cx^2}{m}}
There you go.
m \int_{v_{o}}^{v} vdv= F_{o} \int_{x_{o}}^{x} dx + C_{x} \int_{x_{o}}^{x} dx
should be
sorry i didn't explain it well enough C and X are seperate
so does that mean the solution would be:
1/2mv^2=F_{o}x + 1/2Cx^2
v= \sqrt {(2F_{o}x)/m + (Cx^2)/m}
Oh ok no problem, but at least you got it :smile:
v_{o} = 0 , x_{o} = 0
thanks for your help
Always a pleasure to help, and Welcome to PF! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
