Position vector r and uncertainty principle
MHD93
Hi physicists,
How can two atomic-scale particles interact through gravitation (Gm1m2/r^2) or any other force that is a function of r if r isn't know with complete certainty. Is it that the force itself also comprises uncertainty in its value?
Thanks
In the model where the uncertainty principle is used, we don't use "forces" to describe interactions. The classical equations like the one you used for an example are not used. These are considered to be obeyed only on average.
What happens is that the uncertainty in relative position and momentum leads to an uncertainty in the outcomes of the interactions. Interactions are described by operators on a range of possibilities and the outcome is treated statistically by summing over all possible outcomes.
Also the gravitational attraction between two sub-atomic particles is absurdly negligible. Although you can demonstrate the effect of say Earth's gravity on quantum mechanics through some neat little interference experiments, I believe Shankar (or is it Sakurai) discusses this.
If we use the potential function for such forces (such as the electrical force potential), Doesn't that mean that we use "forces" to describe interactions?
No - it doesn't.
There are lots of different ways to describe situations and interactions - to be true they have to be related to each other. The different descripton lend themselves to different models... eg. compare analyzing a object sliding down a hill via conservation of energy and by Newton's Laws. But, you know, if you want to think of using mv2/2 = mgh is the same thing as using mgsinθ-μN=ma then I'm not going to argue with you ;)
I do want to echo, and add to, @Many_S_Theory's observation - you realize how small the uncertainties in HUP are right? We are not talking about really big variations.
You could argue that "OK, maybe not gravity - but how about electric fields then" in which case I'd want to respond that in the scale where HUP is important, we do not use the electric potential or Coulombs Force Law and so forth ... on that scale the electromagnetic interaction is described in terms of individual photons and Feynman diagrams.
However, I believe:
... answers your original question.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
