Positioning of a concave mirror
The discussion centers on the optical setup involving a convex lens and a concave mirror to create a tightly focused spotlight. Participants clarify that an ellipsoidal reflector and an iris are typically used in stage lighting for precise beam control. The use of a concave mirror as a collector and a convex lens for focusing light is confirmed as a viable method. The lensmaker's equation is recommended for calculating focal lengths to achieve the desired spotlight effect.
  • Understanding of optical principles, specifically light reflection and refraction.
  • Familiarity with convex and concave lenses and mirrors.
  • Knowledge of the lensmaker's equation for calculating focal lengths.
  • Basic concepts of stage lighting instruments, including ellipsoidal reflectors and iris mechanisms.
  • Research the lensmaker's equation and its applications in optical design.
  • Explore the principles of ellipsoidal reflectors and their role in spotlight design.
  • Investigate the use of collimators in creating parallel light rays.
  • Study the effects of tilting concave mirrors on light reflection and focus.
Lighting designers, optical engineers, and anyone interested in the mechanics of stage lighting and optical systems.
pmmiller14
lenses and mirrors??
hi all,
i was wondering what would happen if a convex lens and a concave mirror were set up one after another, the convex len being first to receive the light. how would this work in spot lights? i don't see howa spot light can have a tightly focused spot on a stage, i don't see how it gets there..
when i originally tried to use the graphical method to help me figure this out i relised that i didn't know how the light would reflect off the mirror after being through the lens. does anyone have any theories?
thank you
If you check out the Wikipedia page on stage lighting instruments, you'll find a couple links to the primary classes of spotlights: ellipsoid reflectors and Fresnel lens spotlights. The ellipsoid reflectors are more common, and often have a barrel and gate providing for an iris that let's you control the shape of the beam.
So, that tightly focused spot you see is a result of an ellipsoidal reflector and an iris. It is possible to obtain tightly focused spots with simpler reflectors. A parabolic reflector, for instance, used to be used in old spotlights and anti-aircraft lighting. If you just want to create a beam of light with parallel rays, you can also use a collimator (which is just a curved lens with a light at its focus). Unfortunately, I haven't posted enough to provide links, but Google should turn up a few leads.
Hope this helps!
a.
Thank you aresnick it did help me out a bit.
what if you had to use only concave and convex lenses and mirrors to create the tightly focused spot? when i drew a set up of a light, then a convex lens, then a concave mirror the mirror relfects the light back towards the lens, so would that mean i would have to tilt the mirror?
Yep, you can use the concave mirror as a collector and the convex lens to focus the light. So if you take a look at the lensmaker's equation, you can apply that repeatedly to predict the focal length (which is where you want the stage to be if you're looking for a tightly controlled spot). You'll need to back out the radii of curvature from whatever lenses/mirrors you have available to you.
Good luck,
a.
ahh i see thank you for your help, i appreciate it :)
if the set up goes a light, a convex lens, then a concave mirror how would the light rays reflec off the concave mirror.. that's what i am trying to figgure out.
What do you want the combination of lens plus mirror to accomplish?
to create a spot light, but only have convex lenses and concave mirrors (at varios focal lengths) as materials to do so.
  • · Replies 16 ·
