Possible non-existence of black holes and its consequences
  • Thread starter Thread starter stephenwlin
    Black holes Holes
The discussion centers on the assertion that true black holes do not exist due to their implications of information loss and non-reversibility, proposing instead that apparent event horizons separate causally disconnected universes. The theory suggests that the universe is in a superposition of states, with information between the inside and outside of black holes canceling out to zero, and that Hawking radiation is a result of information leaking from these structures. Critics argue that the claims lack coherence and contradict established physics, particularly regarding the black hole information paradox and the nature of quantum mechanics. The conversation also touches on the relationship between entanglement and gravity, proposing that dark energy and dark matter arise from entanglement within the universe. Overall, the theory presents a radical reinterpretation of black holes and fundamental forces, but faces significant skepticism from the scientific community.
stephenwlin
Here's an idea I came up with recently, that I wanted to share:
Physics is unitary and CPT symmetric, and therefore no true black holes exist, since they imply information loss and non-reversibility. Every "apparent" event horizon is really a separation of two mostly causally disconnected "universes", where the outside universe is entangled with the inside universe. The Hubble volume is sitting inside of an expanding supermassive black hole, of another universe. However, by generalization of the uncertainty principle, this implies that the "outside universe" is "really" simultaneously in a superposition of a large but countably finite many possible universes, with the net information between the "inside" and "outside" views cancelling out to zero. Equivalently, every "classical" black hole is really in a microscopic superposition of countably finite many states, again with the net information "inside" and "outside" cancelling zero. However, it cannot converge to a singularity, because it cannot encode information forever in the same volume, therefore it must eventually leak information in the form of photons (i.e. this retrodicts Hawking radiation).
Similarly, the Hubble volume receives information one photon at a time from the "outside" in the form of cosmic background radiation, that information being about the prior state of the otherwise causally disconnected universe. (i.e. CMB and Hawking radiation are different views of the same phenomena but in different directions). Equivalence between the CMB and Hawking radiation implies that space must be "compressed" within a "black hole" in order to fit all the information that is to leak out later, i.e. length contraction. Also, since information comes out of a "black hole" more slowly than it goes in, this implies time dilation. Therefore, this theory retrodicts the qualitative features of GR.
Gravity between photons is the single fundamental force of the universe. All other sources of apparent information and causal connectivity (i.e. all other forces) are the result of the initial state of the universe at the Big Bang, the only true singularity: the other fundamental particles and forces are the result of bundles of photons taking different paths through microscopic black holes (i.e. microscopic wormholes back to the primordial universe), which exist at every point in 3+1 spacetime.
Here's some testable predictions from this theory:
1. Since no black holes truly exist, the "supermassive black hole" is really wormhole into another part of our universe which is topologically distant when considering only flat 3+1 space.
2. Entanglement and gravity are tied together, in the sense that when entangled particles move apart from each other, the net gravitational pull of the system decreases. When the entangled particles come back together, the process unwinds itself. This is a solution to the EPR paradox: i.e. it explains the mechanism for the apparent non-local transfer of information between entangled particles.
3. The source of dark energy (and possibly dark matter) is entanglement between portions of the visible universe. The fact that this dark matter and dark energy seem to cancel out with visible matter to produce an almost exactly flat local universe is NOT a coincidence: the universe is and must always be approximately flat, from a local point of view.
4. Quantum mechanics is deterministic based on non-local hidden variables (i.e. something like Bohmian mechanics, when extended relativistically, is true).
5. If we probe the observable but non-causally connected universe (i.e. the universe outside the Hubble volume) as deeply as possible, we may be able to find the primordial supermassive wormholes which correspond to the other three fundamental forces of nature.
Here's a bit longer description of what I mean:
http://groups.google.com/group/everything-list/msg/c45c5706ae7cb123
What does everyone think of this idea? Please let me know if you have any questions, too.
Space news on Phys.org
The double posting you have done here and in the S&GR thread is against the PF rules
This already doesn't make any sense. Black-holes do not imply information loss; lots of things are non-reversible, and unitarity + CPT symmetry doesn't directly forbid either of those things anyway.
stephenwlin said:
Every "apparent" event horizon is really a separation of two mostly causally disconnected "universes", [...] with the net information between the "inside" and "outside" views cancelling out to zero.
None of this makes any sense. This is just a stringing together of physics jargon.
Most of the rest isn't even worth noting... except:
What?!
Lots of things are thermodynamically (i.e. statistically) non-reversible. Few things in modern physics (other than "wave function collapse", which is non-mathematical and which many people believe to be a fiction) are irreversible if you run the equations backwards. In fact, it's pretty much only black holes which are, as far as I know:
http://en.wikipedia.org/wiki/Black_hole_information_paradox
So are you saying that the black-hole information paradox is not a paradox? Or are you saying
you "know" the correct answer and it is not the one I am giving? From the article above, it seems like all the answers have problems. My solution is closest to "Information is stored in a baby universe that separates from our own universe", except that I do not think that the universes separate. The baby universe is actually "within" our universe in a higher topological space.
This is an application of the "Computable Universe Hypothesis" and the theory that the algorithmic information in the universe nets to almost zero. See Tegmark for a reference for this hypothesis:
http://arxiv.org/abs/quant-ph/9603008
The rest of my post is not nonsense, I promise you, but you have to prove some real critiques instead of "what!?"
Here's my response on another list to some questions:
http://groups.google.com/group/everything-list/msg/391c732b9377842c
The whole point of CPT is that it's not just T, i.e. time-reversal is NOT an innate symmetry, time-reversal invariance ONLY applied to classical mechanics (not even classical physics in general, i.e. thermodynamics).
I'm saying both. While the wikipedia article doesn't cite many sources, and does not include in-text citations, even a cursory reading of t'Hooft, Susskind, or most importantly Maldacena's papers proves the point quite satisfactorily. Information is preserved via Hawking Radiation.
Well, its very reassuring that you 'promise me'. The whole first part of your post (and thus the premise of your argument is nonsense, and I think similarly of the rest. You're throwing out wild concepts that have zero quantitative motivation or backing, and are completely contradictory to the standard model, both of particle physics and cosmology.
This is not a place to advertise your metaphysical philosophies. Instead of posting about your new theory that replaces all established science, you should make a post asking 'how is the information paradox resolved?' or 'What is the current understanding of black-hole physics?'.
The Schrödinger wave equation, the basis of quantum mechanics and thus most of modern physics other than gravity, is unitary and time-reversible. I sense that you are probably a conservative Copenhagenist, so I guess to you the problem of how you get irreversible (and not just "statistically unlikely to reverse", but truly "irreversible") mechanics from a unitary, reversible equation may not be a problem. However, many physicists, such as Max Tegmark and David Deutsch, for instance, would disagree with your sentiment.
So where do you believe that information is stored in the meantime? Do you think it is "encoded on or just above the event horizon."? How is it physically plausible for the information state of "all matter" that ever flowed into a black hole be stored right on its event horizon? If you can compress information that well, than what's the problem with assuming what I'm assuming, that the information is "compressed" inside as another universe entirely?
I am not throwing out modern physics. I am saying that Einstein was essentially right about everything, more than he even knew, and that topology is basically the source of all physics, including quantum mechanics.
I apologize if I am in the wrong sub-forum. But if you are suggesting that discussion of ideas, no matter how "crazy" they may seem at first, is non-conducive to scientific progress and inquiry, I would very much like to disagree with you.
Anyway, I suggest you read my reply on that other forum. It may clear up some confusion. Finally, I would like to point out that I am providing a concrete mechanism for solving the EPR paradox, other than simply "spooky action at a distance".
Yes, and it is only the basis. As soon as you move to a full quantum field theory... it doesn't apply anymore. Period.
I don't know about Tegmark, he has some wild ideas, but Deutsch most certainly would not disagree.
Its not only plausible. Its established as the case. Holographic principle. AdS/CFT.
The problem has nothing to do with 'the compression of information', but with the idea of the other universe. What sounds more unlikely, 'compressing information' or magically creating a new universe to hide things in? In doesn't even solve your initial problems; it has zero motivation.
Maybe you don't realize it, but you are. Including the entire scientific method.
Thats not what I'm saying at all, I'm saying: "This is not a place to advertise your metaphysical philosophies" in an attempt to circumvent the science which you don't understand.
I am not saying that any of the science is "wrong" except for two things, really: what happens at a black hole, and linkage between entanglement and gravity. Any equations in QFT, QED, QCD, etc. that are correct today are, of course, still correct, but they are a description of the local topology of space-time in our section of the universe due to the initial conditions of the Big Bang and are, in a sense, less fundamental than either GR or QM, which can both be normalized to completely unitless equations using natural Plank units. The rest of the "standard model" cannot, and my theory provides a good reason for that: they are descriptions of primordial events that happened early in our universe rather than of the universe itself. You may notice that this is not all that different than string theory (the "vibrating strings" are essentially photons traveling through microscopic closed local topologies in my picture), the current vogue in attempts to unify QM and GR.
Anyway, I don't see why you're being so uncivil about all this. For one thing, do you mind responding regarding my solution to the EPR paradox? My solution, that net entanglement between states reduces the gravitational pull of a combined system, is unique, as far as I understand. Obviously you are more familiar with the literature though, so if it is not unique, I would appreciate you pointing me in the right direction.
Also, I theorize that the source of "negative pressure" dark energy is the net decrease in gravity in the visible universe due to large-scale entanglement between stars and galaxies. Isn't that unique and testable as well? How is generating a unique and testable hypothesis going against the scientific method?
Also, I'm sorry for double replying, but can you clarify if you are a Copenhagenist when it comes to QM? Just curious.
Stephenwlin, as was pointed out to you when you posted the same thing in the GR forum, you need to submit this to the Independent Research forum, not to the regular forums.
-Ben
