Potential difference between two points located at distances
4 replies · 5K views · last reply
jeff1evesque
Find the potential difference between two points located at distances [tex]R_1[/tex], and [tex]R_2[/tex] from a point source.
Solution
Potential difference = [tex]V_{p_1, p_2} = V_{abs_1} - V_{abs_2}[/tex].
Question
Hows is the solution above true? What if the angle formed between [tex]P_1, Q, P_2[/tex] increases? Don't we have to take this into consideration? If the angle increases, then [tex]P_1[/tex] will be at a larger distance away from [tex]P_2[/tex] (at least until an angle of [tex]\pi[/tex]). Doesn't distance influence the potential difference?
Thanks again,
JL
Potential difference depends on the position of P1 and P2 with respect the the field, not on the path from P1 to P2.
Is that a definition, or can it be justified?
Yes. It is the basic theorem.
If you lift an object to certain height, rise in potential energy is = mgh, irrespective of the path through the object is taken.
Both electric fields and gravity fields, which rl.bhat mentions, are called conservative fields, meaning that the path taken from A to B does not matter. Friction is non-conservative, by counterexample. Since the electric field is conservative, you can describe its potential with a scalar rather than a vector. You're right that distance affects potential difference sometimes, but this is taken into account when you calculate the individual potentials V1 and V2. But because it's a scalar potential, the angle does not matter, only the distance.
