Why is Equal and Opposite Force Necessary for Work Against a Field?
The discussion centers on the necessity of applying a force greater than the opposing field force to initiate motion in an object at rest. Participants clarify that while the applied force must initially exceed the field force to overcome inertia, it can later match the field force during motion. The conversation emphasizes the relationship between work, kinetic energy, and potential energy, highlighting that the work done against a field is represented by the integral of the applied force over displacement. This nuanced understanding is crucial for accurately calculating work in physics.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of work, kinetic energy, and potential energy
  • Knowledge of vector calculus for integrating force over displacement
  • Basic grasp of field forces in physics
  • Study the relationship between force, work, and energy in classical mechanics
  • Learn about the integral calculus application in physics, specifically in calculating work done
  • Explore the concept of field forces and their implications in different physical scenarios
  • Investigate the differences between net work and work done against a field
Students of physics, educators teaching mechanics, and anyone interested in the principles of work and energy in physical systems will benefit from this discussion.
ViolentCorpse
Hello everyone!
When we do work against a field on an object, why must the force we apply on it be equal and opposite to that of the field? If the object is initially at rest, then shouldn't we be applying a force greater and opposite to that of the field to first set it into motion? We could later make it equal after the object has been set into motion, but the first initial push should be greater.
Thank you! :)
ViolentCorpse said:
Hello everyone!
Thank you! :)
You are quite right. If the applied force was always equal and opposite, there would be no net force and, so, no acceleration. The applied force has to be just a tad greater initially in order to give the body some velocity and then it can be reduced to be equal in magnitude to the field force.
AM
That extra force needed for acceleration goes into kinetic energy, which is released when the object stops again. For "work against a field" we usually consider just the potential energy part.
If we want to do work against the field,the force must not be equal to that of field. We need to apply a force greater than what the field exerts on the object
True
That applies only to an object initially at rest. In general, positive work is done on a body by an applied force against the field force if the direction of the applied force is opposite to the direction of the field force and if it is applied through some positive displacement. It doesn't necessarily have to be greater in magnitude than the field force.
AM
Shouldn't the entire journey of that object against the field comprise of part potential and part kinetic energy?
Thank you so much each and everyone of you!
If you meant that the work done by an external force, F, in moving the body from point a to point b: (\int_a^b \vec{F}\cdot d\vec{s}) must be equal to the sum of the change in kinetic energy + change in potential energy of the body from a to b, then the answer is: yes.
AM
Thank you for clearing that, though I know that much. I'm just trying to see how accurate it is to express work done against the field as F.ds, if that F was a little more than F for a very short period of time to get the object moving in the first place..
What is F here?
If F is the negated field-force then integral F.ds is the work done against the field.
If F is the net force, then integral F.ds is the net work done.
If Fa is the applied force and Ff is the field force, the work done by the applied force on the object in moving from a to b is: \int_a^b \vec{F_a}\cdot d\vec{s}, which consists of the change in potential energy + change in kinetic energy. The work done against the field is \int_a^b \vec{F_f}\cdot d\vec{s}, which is just the change in potential energy.
AM
Oh, I think I get it now. I'm clearly not a very bright student.
Thank you, Andrew Mason and A.T for your continued help. I very much appreciate it.
On the contrary. You asked a very good question. This is something that many physics texts gloss over. You learn by asking questions. The only kind of dumb question is one that should have been asked - but wasn't.
AM
That's really very nice and encouraging of you, Mr. Andrew Mason. Thank you! :smile:
  • · Replies 54 ·
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 77 ·
