Potential energy loss related to force applied?
The discussion centers on the calculation of potential energy loss in a system where forces are applied but no motion occurs. Participants explore the implications of a stalled motor in a battery-operated car that attempts to move against a wall, examining the relationship between force, energy loss, and work done.
  • One participant inquires about calculating potential energy loss when a battery-operated car pushes against a wall without moving, suggesting that energy is lost despite no work being done.
  • Another participant asserts that energy loss from the battery occurs as heat in the motor coils, proposing a calculation based on current, voltage, and time.
  • A follow-up question seeks a method to calculate energy loss directly from the force applied over time, rather than relying on internal measurements.
  • Some participants emphasize that if no work is done (due to zero motion), there is no mechanical energy loss, and energy loss is only due to electrical resistance in the system.
  • One participant confirms that there is no equation relating potential energy loss to an integral of force and time, clarifying that impulse relates to momentum change, which does not occur without motion.
Participants generally agree that if no work is done, there is no mechanical energy loss. However, there is disagreement regarding the calculation of energy loss and the relationship between force and potential energy in a stalled system.
Participants note limitations in measuring internal flows and the implications of electrical resistance in the context of energy loss calculations.
This discussion may be of interest to those exploring concepts of energy loss in electrical systems, mechanics of stalled motors, and the relationship between force and energy in non-moving systems.
Joey Wilson
How can I calculate the loss of potential energy when forces are applied but no motion in the system occurs? Here's an example:
Let's say I build a battery operated car that is set to drive forward, but I put it right in front of a wall. It attempts to drive forward, but instead it just pushes into the wall and nothing moves. The battery will continue to drain, and thus potential energy is being lost, yet no work is happening. The car and the wall do not move. Let's assume that the car is able to push the wall with a consistent force of 1 Newton.
If I know how long the car has been pushing (let's say for one hour), can I calculate the potential energy loss based on the fact that the car has been pushing with 1 Newton, for one hour? The work is zero because if W=fd, the distance is 0, so the work is zero. Yet, there definitely is a loss of potential energy in the battery. How can I calculate that?
If there is no motion, then all the energy loss of the battery goes into heating the coils in the motor. You can calculate that if you know the current ##I## that the stalled motor draws. Then ##E = IVt## where ##V## is the battery voltage and t = 3600 s. That's assuming that the battery voltage stays constant and the motor doesn't burn out.
Thank you for the reply. I'm wondering if there is a way to directly calculate the energy loss based on the force applied over time, rather than calculating from internal workings. The reason is we can measure the force applied over time, but measuring the internal flows is not possible.
If no work is done (no motion) then there is no mechanical "energy loss". A Force X Zero Distance involves No Work. When a motor is stalled, there is no back emf to restrict the current through the armature and energy is lost only in the resistance of the wires - and, of course, in the Power source (internal resistance of a battery for instance). The lost Power has to be measured with electrical meters.
OK - so you're saying there is no equation that relates potential energy loss to an integral of force and time?
That is correct. ∫Fdt is impulse which is equal to change in momentum. If nothing is moving, there is no change in momentum. Besides, impulse and energy have different dimensions.
  • · Replies 54 ·
  • · Replies 31 ·
  • · Replies 16 ·
  • · Replies 46 ·
