Power calculation for a sprinter
The power generated by a 100m sprinter can be calculated using the formula P = (F*d)/t, where F is the force exerted, d is the distance, and t is the time taken. For a sprinter weighing 60kg, the force is calculated as 588.6N, leading to an initial power output of 5,886W or approximately 7.89 horsepower. However, a more accurate calculation considering constant acceleration yields a power output of 1,200W or 1.6 horsepower. This discrepancy highlights the importance of accounting for acceleration and the dynamics of sprinting.
  • Understanding of basic physics concepts such as force, work, and power.
  • Familiarity with the SUVAT equations of motion.
  • Knowledge of unit conversions, particularly between watts and horsepower.
  • Basic grasp of human biomechanics in sprinting.
  • Study the SUVAT equations of motion in detail to understand acceleration calculations.
  • Learn about the effects of air resistance on sprinting performance.
  • Research human biomechanics to gain insights into the forces involved in sprinting.
  • Explore the relationship between power output and sprinting times in elite athletes.
Athletes, coaches, sports scientists, and anyone interested in the physics of sprinting and performance optimization will benefit from this discussion.
luzirahs
Power generated by a 100m sprinter.
hai all,
i've been thinking about how much horsepower does a human generate during a 100m sprint...
(after my friends joking with me by telling me running on dyno machine's roller to measure my horsepower. :redface:)
is it possible for me to use P = (F*d)/t, where
F is the sprinter weight, (coz i think its the only force/mass that been moved, or got any other force involve, too?)
d is 100m and
t is his sprint time.
let's say mass of the sprinter is 60kg,
therefore his weight is 60kg*9.81m/s^2 = 588.6N
and his 100m sprint time is 10s sharp.
so, power generated by the sprinter is,
P = (588.6*100)/10
P = 5,886W
P = 5,886W*(1hp/746W)
P = 7.89hp
its so true that if the sprinter can sprint 100m less than 10s, his horsepower generated for the sprint will be higher, which is make sense to me.
am i correct?
thanx all.
The force isn't his weight - unless he is sprinting vertically up! Draw a sketch - it will help.
You could assume that the sprinter is always accelerating and use F=ma.
I suspect that sprinters reach maximum velocity in a couple of seconds and then it is a more complicated question of air resistance and the force of lifting each leg on each stride. Sprinters try and run so that their centre of gravity remains level.
You could estimate how much a leg weighs and how far it moves up and down on each stride.
As a tip - human powered vehicles generally reckon on about 1/4 - 1/3Hp from a cyclist!
thanx mgb_phys for your reply and tips.
in this kind of problem, i assume that the sprinter accelerates w a constant acceleration from starting block to finishing line.
after some Googling, i found this link (http://answers.l.google.com/answers/threadview?id=519149 ) to answer my question.
here's the calculations (referred from that link)...
sprinter mass = 60kg,
his sprint time is 10s.
his final speed is,
v = 100m/10s = 10m/s
* this is average speed, along the sprint.
In order to find the force wee need to know the acceleration.
Using SUVAT equations of motion we have,
s = 100m
u = 0m/s
v = 10m/s
a = ?
t = 10s
using,
s = ut + (0.5)at^2
s = (0.5)at^2 (we lose ut because 0x10 = 0)
therefore,
100 = (0.5)*a*10^2 ...rearrange to find a,
a = 2 m/s^2
This acceleration is an average acceleration along the sprint...a constant one.
Then,
F = ma
F = 60x2 = 120N
After that,
Work done = Force x Distance Travelled
W = 120x100 = 12,000J
Power = Work done / Time taken
P = 12,000J/10s = 1,200Watts
Finally, to get Power in horsepower unit, divide Power by 746.
P = 1,200W*(1hp/746W)
P = 1.6hp
If he completes the 100m in 10s and is constantly accelerating the final speed is not 10m/s - although you don't use it in the calcs.
1.6hp sounds a lot but I suppose as it is only for 10secs it is possible.
19K
