Power Dissipation in Resistive Circuit Conceptual Question
The discussion focuses on calculating power dissipation in a resistive circuit with two identical resistors in series. The total power dissipated by the first resistor is defined as P_0. When a second identical resistor is added in series, the power dissipated is calculated using the formula P = I^2 * R, leading to the conclusion that the power dissipated by the series circuit is P(f) = (1/2)P(0). This is due to the halving of current when resistance doubles, confirming that the correct approach involves understanding the relationship between voltage, current, and resistance.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of power formulas in electrical circuits (P = V^2/R and P = I^2R)
  • Familiarity with series circuits and their properties
  • Basic algebra for manipulating equations
  • Study the impact of series and parallel resistor configurations on total resistance
  • Learn about power dissipation in AC circuits
  • Explore the concept of equivalent resistance in complex circuits
  • Investigate the effects of temperature on resistor performance
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of power dissipation in resistive circuits.
sushii9
Hey guys, so I have a homework question that I have already solved one way, but when I try it another way I can't seem to get the correct answer.
First of all, the question is:
"A single resistor is wired to a battery as shown in the diagram http://session.masteringphysics.com/problemAsset/1011457/10/1011457A.jpg" Define the total power dissipated by this circuit as P_0.
Now, a second identical resistor is wired in series with the first resistor as shown in the second diagram http://session.masteringphysics.com/problemAsset/1011457/10/1011457B.jpg" .
What is the power, in terms of P_0, dissipated by this circuit?"
Relevant equations:
P = V^2/R = I^2*R
So I have solved the equation by using V^2/R (P = V^2/(2R) = P_0/2), however the first way I tried to solve it was with I^2*R. I know this equation is correct, so why doesn't it give me the right solution? If anyone could give me an explanation I would be grateful. (My work is shown below)
P = I^2 * (R + R) = I^2 * 2R = 2 * P_0 ?
So I guess you are treating the two resistors as one resistor with double the resistance?
Would the current really be the same? I think you may find the V=IR, so I=V/R, if the V is constant and the resistance doubles then the current will half.
so I(f) the final current (after the addition of the second resistor) is half the initial current, I(s).
so
P(0)=I(s)^2*R
P(f)=I(f)^2*2R
=(1/2 I(s))^2*2R
=(1/4)I(s)^2*2R
=(1/2)P(0)Edit to ask: Does that make sense?
  • · Replies 24 ·
