Power factor at half power points for RLC circuit
5 replies · 7K views
Loki
Can anyone help me with this homework problem? I worked it through, but the answer i get doesn't agree with the answer the book gives. I'll include my work, and if anyone can help, I'll be eternally grateful, at least for a while.
The Problem:
In a series RCL circuit the dissapated power drops by a factor of two when the frequency of the generator is changed from the resonant frequency to a nonresonant frequency. The peak voltage is held constant while this change is made. Determine the power factor of the curcuit at nonresonant frequency.​
My Work:
[tex]P_r = 2 P_{nr}[/tex]
[tex]P = I * V * \cos \phi[/tex]
[tex]\phi = \arctan \frac{X_L - X_C}{R}[/tex]
At resonant frequency, [itex]X_L - X_C = 0[/itex]
[tex]I * V * \cos ( \arctan \frac{X_L-X_C}{R} ) = 2 * I * V \cos (\arctan\frac{X_L-X_C}{R})[/tex]
[tex]I * V * \cos ( \arctan (0)) = 2 * I * V \cos (\arctan\frac{X_L-X_C}{R})[/tex]
[tex]I * V * \cos (0) = 2 * I * V \cos (\phi)[/tex]
[tex]1 = 2 \cos (\phi)[/tex]
[tex]\cos \phi = \frac{1}{2}[/tex]
This seems correct to me, but the book says the answer is [itex]\frac{\sqrt {2}}{2}[/itex]
Am I mistaking the "Factor of two" part of the problem? Does this really mean that the power is squared?
If anybody can help, thanks. On a sidenote, LaTeX is very nice, if a bit tedious to write in.
A complete solution is offered.
At resonance the current is in phase with the voltage source, and the power factor is 1. In that case the power dissipated is simply
##P_o = \frac{V^2}{R}~~~##where ##R## is the circuit resistance and ##V## the fixed voltage.
We are looking for the power factor for the situation where the dissipated power drops by a factor of two. That is,
## P = \frac{P_o}{2} = \frac{V^2}{2R}##
Off-resonance there will be a net reactance, X. We won't worry about the individual reactances of the inductance and capacitance, only their net effect. Let:
##Z = R + j X## be the impedance at the off-resonance frequency.
Then the complex power (apparent power) for the circuit is given by:
##p = V~I^* = V ⋅ \frac{V}{(R + jX)^*} = V^2 \frac{R + jX}{R^2 +X^2}##
where ##I^*## means the complex conjugate of ##I##.
Now, the real power dissipated is the real component of the complex power. Setting this equal to our desired value:
##\frac{V^2}{2R} = V^2 \frac{R}{R^2 +X^2}##
Solving for the reactance we find that ##X = R##. This means that the impedance has a value ##Z = R (1 + j)##, which has a phase angle of 45°. The current, which is V/Z will have an angle of -45°. The cosine of -45° is ##\frac{\sqrt{2}}{2}##, so that is the power factor.
Note that the reactance could be positive or negative (net inductive or net capacitive reactance), and that the power factor will be the same since ##~~~cos(-45°) = cos(45°) = \frac{\sqrt{2}}{2}##.
Here's my two cents..
At resonance,
Pr=VIr..(cosΦ=1)
At non-resonant frequency,
Pnr=VInrcosΦ
But Pr=2Pnr
So,
VIr=2VInrcosΦ
∴Ir=2InrcosΦ
∴V/R=2*(V/Z)cosΦ
...(R remains same in both the cases)
∴Z/R=2cosΦ
Since R/Z is cos Φ, we can directly write,
2cos2Φ=1
∴cosΦ=1/√2=0.7071
(=√2/2 as given in the answer)
Nice. That works. It's great to see variations!
Why do you set ##I=\frac{V}{R-JX}## instead of ##\frac{V}{R+JX}## In other words, why use the complex conjugate and not Z as it is?
Because the complex power is given by ##P = V I^*##. See, for example: An Introduction to Electric Circuit Theory by G. Williams, section 5.8. Since the V that we are using here is purely real, the way to form the complex conjugate is to change the sign of the imaginary term in the impedance in the denominator.
