Powering a 250 VDC Motor with 390 VDC – Questions?
  • Thread starter Thread starter EEFinder
    Motor
The discussion revolves around the operation of a 250 VDC motor that is reportedly receiving 390 VDC. Participants explore the implications of this voltage discrepancy, including potential effects on motor performance and the accuracy of voltage measurements.
  • One participant questions the concept of a motor "drawing" voltage, suggesting that motors operate based on current rather than voltage.
  • Another participant clarifies that the issue pertains to a voltage reading of 390 VDC instead of the expected 250 VDC.
  • A suggestion is made to adjust the voltage regulator, noting that motor speed at constant load is proportional to voltage.
  • One participant expresses confusion about the unchanged speed of the motor despite the higher voltage reading.
  • A question is raised regarding the nature of the power supply and its capability to provide 390 volts.
  • Concerns are mentioned about the accuracy of an analog meter, particularly if it was set to the AC volts scale while measuring DC voltage.
  • A participant recounts an incident involving an electrician who was unsure if his meter was set correctly for DC measurements.
Participants do not reach a consensus on the implications of the 390 VDC reading, with multiple viewpoints regarding the accuracy of measurements and the motor's performance under these conditions. The discussion remains unresolved.
There are limitations regarding the assumptions about the measurement tools used and the conditions under which the motor operates. The discussion highlights uncertainty about the accuracy of voltage readings and the implications for motor operation.
This discussion may be of interest to electrical engineers, technicians working with DC motors, and individuals involved in troubleshooting electrical systems.
EEFinder
A 250 VDC motor drawing 390 VDC!
any one with any explanation?
Thanks.
Thanks.
Motors do not "draw" voltage...
Thanks for the reminder, I used the wrong word, and it is not current
the Voltage reading instead of being around 250VDC, it was around 390VDC
Adjust the voltage regulator. Is the speed OK at 390VDC, motor speed at constant load is proportional to voltage.
thanks for the replay,
and that's what baffled me, the speed looked unchanged!
What's going on with drawn current?
? What is nature of supply? Is it capable of 390 volts ?
An analog meter that's set to AC volts scale will report high if connected to DC volts.
Jim,
That was actually the case.
By the end of the day on Thursday one of the electrician reported the situation. when I checked it on Friday morning, as well as few other times during the day, it was right on the money. When reviewed the Situation with the electrician, he stated that he was not sure if his meter was sat on DC!
  • · Replies 42 ·
9K
