Powers analisys for ball stuck in a Chimney
  • Thread starter Thread starter sronen20
    Ball Stuck
A ball thrown down a chimney with decreasing width will get stuck due to the increasing normal force required to counteract gravity. The forces acting on the ball become complex as the slope of the walls approaches zero, leading to a situation where the normal force appears to approach infinity. In a frictionless scenario, the ball experiences compressive forces that prevent it from moving further down. Realistically, friction would play a significant role in this scenario, affecting the ball's motion. Understanding these dynamics is crucial for accurately analyzing the forces at play.
sronen20
Hi,
If we'll build a chimney from 2 walls with a decreasing width (meaning, the length between the walls gets smaller as we go down the chimney, since the walls both have a small slope), and then throw a ball down that chimney, it would get stuck.
I am having hard time computing the forces that cause this affect. in order to resist the gravity, it seams I need very strong normal force (going to infinity as the slope goes to 0).
but when I try to express mg by perpendicular and Tangent vectors, I receive values smaller then mg (and obviously not going to infinity).
can someone help?
sronen20 said:
Hi,
can someone help?
You are solving the problem without friction. In a real chimney, it would be friction acting tangentially to the wall, not a balanced force acting normal to the wall. Your answer is correct- a frictionless ball in a nearly parallel chimney would get stuck at a place with nearly infinite compressive forces on it.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
