Preacceleration in radiation reaction solutions
The discussion centers on the radiation reaction problem in classical electromagnetism, highlighting concerns about the derivation methods used in textbooks and articles by Griffiths and Jackson. A key issue raised is the assumption of continuous acceleration, which leads to unphysical results like preacceleration when using the self-force approach. The possibility of deriving the self-force without relying on Taylor expansion to avoid this assumption is suggested. Participants mention that classical electromagnetism struggles with point-particle models due to its continuous-media nature, and they reference the Lorentz-Dirac equation and works by Dirac and Teitelboim for further insights. The conversation concludes with a mention of a resource that may address the analyticity of solutions related to radiation reaction.
zlasner
Hi,
I have been studying the radiation reaction problem and I see a weakness in the derivation that hopefully someone might illuminate for me. In the textbooks by Griffiths and Jackson, as well as some journal articles I have found, the radiation reaction seems to be "derived" by a suggestion from conservation of energy, and also derived more rigorously from the self-force of a charge distribution. When the charge distribution becomes smaller than a critical limit, we get "unphysical" behavior like preacceleration.
It seems to me that the reason preacceleration occurs is that the acceleration is required to be continuous when the radiation reaction is included in the equation of motion (ma = F + tau*a'). But in the derivations of the self-force, it most authors Taylor expand the velocity, which hides an ASSUMPTION that acceleration is continuous (so that it's differentiable).
I'm wondering if one can avoid the requirement that acceleration is continuous, and therefore avoid preacceleration solutions, by deriving the self-force without Taylor expanding velocity (and therefore without implicitly ASSUMING that acceleration is continuous).
Does anyone have thoughts about this, or references wherein this has been attempted?
Science news on Phys.org
The problems here - the one you said about preacceleration but also others like runaway solutions or negative non-electromagnetic mass - arise from the fact that classical electromagnetism is a continuous-media theory, so it tends to fail when you try to use point-particles. Fortunately we have QM...
Anyway, try googling "Lorentz-Dirac equation". You can find old articles by Dirac on this topic. There is another article I read some time ago, I only remember one of the authors: Teitelboim.
I'm not sure one should expect a continuous-media theory to give incorrect results when the limit is taken as the size of a distribution goes to zero. To me, that is analogous to saying that general relativity shouldn't give the correct results in the limit of flat spacetime because it is a curved-spacetime theory. Of course, as you mentioned, the truly correct theory to use here is QED, but I don't think the problems arise because there is anything wrong with taking a limit in an otherwise consistent, reasonable theory. (We do this all the time with other limits and other theories, after all.)
Thanks for those suggestions. I found something else that might address the problem of analyticity in the solution of the radiation reaction:
http://books.google.com/books?id=bZ...q=yaghjian lorentz&pg=PP1#v=onepage&q&f=false
I'm not sure yet whether its solution is satisfying to me, but I'll try to get hold of it and see.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
