Predator/Reaper, why they went with a V-tail design?
  • Thread starter Thread starter RandomGuy88
    Design
The discussion centers on the design choices of the Predator and Reaper UAVs, specifically their tail configurations. The Predator features a downward-pointing V-tail, which was influenced by ground clearance requirements and the coupling effects between yaw and roll. In contrast, the Reaper, an advanced version of the Predator, utilizes a Y-tail design along with a vertical stabilizer to enhance weathercock stability. These design elements are crucial for the operational capabilities of both aircraft.
  • Understanding of UAV aerodynamics
  • Familiarity with tail configurations in aircraft design
  • Knowledge of yaw and roll coupling effects
  • Basic principles of stability in flight
  • Research the aerodynamic principles behind V-tail and Y-tail designs
  • Explore the impact of tail configurations on UAV performance
  • Learn about the MQ-9 Reaper's design specifications and capabilities
  • Investigate the role of vertical stabilizers in enhancing aircraft stability
Aerospace engineers, UAV designers, aviation enthusiasts, and anyone interested in the aerodynamic principles of unmanned aerial vehicles.
RandomGuy88
I have some questions about these two aircraft.
Does anyone know why they went with a V-tail design?
My understanding is that the Reaper is a more advanced version of the Predator. Why is the tail of the Predator point downwards but not the tail of the Reaper? I have heard that the Predator's tail was upside down because of the coupling between yaw and roll that the V-tail creates. If an upside down V-Tail tries to yaw the aircraft to port then the aircraft will roll to port, but if the V-Tail is right side up and it yaws the aircraft to port then it will create a rolling moment to starboard. Was this an actual reason for this tail config, or are the rolling moments from the V-tail to small to worry about? And if so what was the reason? It seems like a downwards pointing V-tail could have ground clearance issues.
The Reaper also has a vertical stabilizer in addition to the V-tail. Why is that?
The MQ-9 is much larger than the predator, and flies a bit faster. For the MQ-9, its a Y tail, not a V tail.
It was an issue of ground clearance for the landing gear.
Yep.
For more weathercock stability.
  • · Replies 21 ·
  • · Replies 34 ·
9K
10K
11K
9K
  • · Replies 23 ·
  • · Replies 52 ·
