Predict sign of partial derivatives
The discussion focuses on predicting the signs of partial derivatives of temperature T based on its dependence on longitude, latitude, and time. It is established that as latitude increases northward, the temperature decreases, indicating that the partial derivative with respect to latitude (dT/dy) is negative. The conversation also highlights the importance of understanding how longitude affects temperature, noting that as longitude increases westward, the temperature may also decrease, leading to a potentially negative dT/dx. Additionally, the impact of time on temperature (dT/dt) is discussed in relation to the movement of warm air. Overall, the thread emphasizes the need to analyze how each variable influences temperature changes in the context of the given scenario.
fk378
The temperature T at a location in the Northern Hemisphere depends on the longitude x, latitude y, and time t so we can write T=f(x,y,z); time is measured in hours from the beginning of January.
Honolulu has longitude 158 degrees W, and latitude 21 degrees N. Suppose that at 9:00 AM on January 1, the wind is blowing hot air to the northeast, so the air to the west and south is warm and the air to the north and east is cooler. Would you expect fx(158, 121,9), fy(158, 121,9), and ft(158, 121,9) to be positive or negative? Explain.
dT/dx = change in temperature as longitude varies
dT/dy = change in temperature as latitude varies
dT/dt = change in temperature as time varies
As longitude varies, the temperature in the north would get cooler, so would it be a negative partial derivative?
I'm not sure how to approach this.
There is no special trick to partial derivatives: they still express rates of change of a function with respect to a change in an independent variable -- there is just more than one variable now.
The value of (North) latitude is increasing as you go north, while the temperature is falling. So you are correct that dT/dy < 0 . (I presume you meant 'latitude' in your question, since you mentioned the temperature 'in the north'.)
Be careful about dT/dx: what longitude is being used and which way does it increase? As for dT/dt, you need to consider how the air is moving and what will happen to the temperature at Honolulu as time passes...
try to draw a graph of temperature
if
keeping y and z constant, and x goes from a (less positive x) to b (more positive x), and Temperature decreases, then dT/dx is?
Crucial point is what dynamicsolo implied: x increases to the WEST.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
