Undergrad Preprocessing FIT Files to Bias and Flat Correction Using Python Script
  • Thread starter Thread starter tryingtolearn1
    files Fit
The discussion focuses on preprocessing FIT files for astronomical imaging using a Python script, specifically addressing the roles of bias, flat, standard star, and target files. It emphasizes that the target files contain the actual observations, while standard stars are used for calibration to obtain quantitative measurements of brightness. The process involves subtracting the median bias from the flat files, normalizing them, and then using standard stars to calculate calibration factors based on known brightness and exposure parameters. There is also a need to align images due to slight shifts, which can be determined using standard stars. Understanding the function of standard stars is critical for achieving accurate photometric and astrometric measurements.
tryingtolearn1
TL;DR
I am trying to understand the steps for prepossessing fits files and what exactly needs to be done with the target and standard stars files.
I have a list of about 35 fit files, where there are 10 dome flats files, 10 bias files, 10 standard stars files, and 5 target files. Where each file has been filtered with BVI filter. So a third of the dome flat files were taken with a I-filter, a third with V-filter and a third with B-filter and so on with the remaining files.
I am using a python script to conduct the pre-processing. When conducting preprocessing, I understand you need to first apply a bias and flat correction by finding the median of all the BIAS files and subtracting that median from each of the dome flat files. Once you subtracted the median for each of the DOME files then you get the median of the DOME-subtracted files which then you can normalize. I understand this two parts but what exactly is the target and standard files for? What do I need to do with those files?
Astronomy news on Phys.org
Well, I don't know exactly what you are trying to do, but probably the target files have the actual observations of the objects you care about. All of the other files (dome flats, bias, standard stars) are used to calibrate the target files so you can get quantitative measurements of the objects you care about. The standard star files should have images of "standard" stars of a known brightness so that you can determine the calibration factors from the measured instrument counts to actual number of incoming photons.
Likes tryingtolearn1
Thank you now I understand about that the image that needs to be calibrated is the target but I am still confused about what needs to be done with the standard star.
For example,
I am looking at the following astronomical images that are fits files.
I understand that the dome and bias files need to be calibrated by subtracting the bias from the flat and normalizing it but what calibration needs to be done with the standard star?
So after you've done the bias subtraction and flat normalization to the standard star file, you do the following:
(1) Take one of the standard stars and add up all of the signal within some radius. You'll have to decide how far out to go to get all of the light that arrived from the star.
(2) Now knowing the brightness of the star, the exposure time, the filter bandpass, and the telescope aperture, you should be able to calculate how many photons arrived at the telescope from the star in that time.
(3) This gives you the calibration factor from the signal as reported in your fits file to actual photons.
Does this make sense?
Hmm, just so I understood correctly, the reason why we need to calibrate the standard star with the target is because the images are each slightly shifted from each other therefore we need to align the images? And in order to align the images we will need to choose one of the standard star which will be used to figure out how much each other frame is offset by in pixels?
I actually just opened both the target fits file and one standard star on DS9 and both images are noticiably different but are similar so what exactly is the difference between a standard star and target?
What are you trying to do? Just make a pretty picture or do a quantitative measurement?
I am following this tutorial but with a different dataset in order to practice preprocessing (https://users.astro.ufl.edu/~ajtownsend/OBSTECH_REDUX_2017.html) . The thing that throws me off is that in that tutorial there were no standard stars. There were only BIAS, FLAT and TARGET. But in this dataset, it has BIAS, FLAT, STANDARD STARS and TARGET. I am not sure what I am suppose to do with the standard stars.
The standard stars allow you to do quantitative photometric measurements. Without the standard stars you get an image, but you have no idea how bright anything is, quantitatively. If you have the locations of the standard stars, they also allow you to do quantitative astrometric measurements.
  • · Replies 16 ·
  • · Replies 152 ·
10K
