Pressure drop through connected cylinders with different diameters
4 replies · 3K views · last reply
anthonynichola
Hello, is there anyone who can help me with this? I am completely stumped. Here is the situation:
Point A: Water is flowing into a valve at 559 (mbar) of pressure and into a cylinder that's 12 mm long and 7mm in diameter.
Point B: It then will enter another cylinder that is 40 mm long 10 mm in diameter.
Point C: At this point it will enter another cylinder 5mm long and 7mm in diameter.
Im trying to figure out what the pressure will be at Point C so that I can choose the correct umbrella valve to use so that water flows out of the chamber.
Many... :smile:
If all the points : A,B and C lie in the same streamline, you can apply "Bernoulli's Theorem", at A,B and C respectively.
Best of luck buddy ! :)
Thanks! Does this apply also if I change the shape of the chamber? Meaning, instead of a cylinder its an oval? I am young and inexperienced lol
Provided that when the shape of chamber is changed, that is A,B and C are ovals, then also you can apply Bernoulli's Theorem, if A,B and C lie in a same streamline.
I'm young and inexperienced lol
And So am I. :-p
If the flow is incrompressible and also irrotational then you can apply Bernulli's theorem between any points in the flow.
