Fermion Pressure at Room Temperature
The discussion focuses on calculating the mean energy and pressure of a system of N fermions with spin 1/2 at room temperature. The mean energy is derived using the formula <E> = (V/λ³) kT Σ (-1)^(l+1) z^l/l^(5/2), where z is the fugacity. The pressure is calculated as P = (2/3) (1/λ³) kT Σ (-1)^(l+1) z^l/l^(5/2). A critical error was identified in the calculation of the Gamma function, where Γ(5/2) was incorrectly assumed, leading to confusion regarding the factor of 2/3 in the pressure equation.
  • Understanding of quantum statistics, specifically Fermi-Dirac statistics.
  • Familiarity with thermodynamic concepts such as pressure and mean energy.
  • Knowledge of the grand canonical ensemble and partition functions.
  • Proficiency in calculus, particularly in evaluating integrals and series.
  • Study the derivation of the Fermi-Dirac distribution and its implications for fermionic systems.
  • Learn about the grand canonical ensemble and its application in statistical mechanics.
  • Explore the properties of the Gamma function and its role in statistical calculations.
  • Investigate the differences between fermions and bosons in statistical mechanics.
Physicists, graduate students in quantum mechanics, and anyone studying statistical mechanics, particularly those interested in the behavior of fermionic systems at room temperature.
FranciscoSili
I have to find the mean Energy $<E>$ and pressure of a system of N fermions with spin 1/2. The energy per particle is
\begin{equation}
\varepsilon = \frac{p^2}{2m}.
\endu{equation}
The relevant equations are the degeneracy of the system:
\begin{equation}
g(\varepsilon)=\frac{4V (2m)^{3/2}\pi\varepsilon^{1/2}}{h^3}
\end{equation}
the mean occupation numbers of fermions
\begin{equation}
<n_\varepsilon>_{FD} = \frac{1}{e^{\beta(\varepsilon - \mu)}+1}
\end{equation}
I calculated the mean energy doing
\begin{equation*}
\begin{split}
<E> &= \int_{0}^{\infty} \varepsilon g(\varepsilon) <n_\varepsilon>_{FD} d\varepsilon\\
&= \frac{4V (2mkT)^{3/2}\pi}{h^3} kT \int_{0}^{\infty} \frac{x^{3/2}}{z^{-1}e^x+1}dx.
\end{split}
\end{equation*},
and finally obtained:
\begin{equation}
<E> = \frac{V}{\lambda^3} kT \sum_{l=1}^{\infty} (-1)^{l+1}\frac{z^l}{l^{5/2}}
\end{equation}
\begin{equation*}
z=\exp{\beta \mu}
\end{equation*}Then I calculated the pressure making use of the grand partition function
\begin{equation}
\mathcal{Z} = \prod_\varepsilon 1+e^{-\beta(\varepsilon - \mu)}
\end{equation}
and doing this
\begin{equation*}
\begin{split}
\frac{PV}{kT} &= \ln \mathcal{Z} = \sum_{\varepsilon} \ln \left(1+e^{-\beta(\varepsilon - \mu)}\right)\\
&= \frac{4V (2m)^{3/2}\pi}{h^3} \int_{0}^{\infty} \varepsilon^{1/2} \ln \left(1+e^{-\beta(\varepsilon - \mu)}\right) d\varepsilon\\
&= \frac{4V (2m)^{3/2}\pi}{h^3} \left[\frac{2}{3} \varepsilon^{3/2} \ln \left(1+e^{-\beta(\varepsilon - \mu)}\right)\Big|_0^{\infty} - \frac{2\beta}{3} \int_{0}^{\infty} \frac{\varepsilon^{3/2}}{e^{\beta(\varepsilon - \mu)}+1} d\varepsilon \right]\\
&= \frac{8V (2m)^{3/2}\pi}{3h^3} \beta \int_{0}^{\infty} \frac{\varepsilon^{3/2}}{e^{\beta(\varepsilon - \mu)}+1} d\varepsilon
\end{split}
\end{equation*}
I finally obtained that the pressure is
\begin{equation}
P = \frac{2}{3} \frac{1}{\lambda^3} kT \sum_{l=1}^{\infty} (-1)^{l+1}\frac{z^l}{l^{5/2}}
\end{equation}
Now, the problem is that, if I want to obtain the pressure at room temperature, I calculate using the canonical ensemble the chemical potential, and approximate the series
\begin{equation}
\mu = \frac{1}{\beta} \ln \left(\frac{N \lambda^3}{V}\right),
\end{equation}
\begin{equation}
\sum_{l=1}^{\infty} (-1)^{l+1}\frac{z^l}{l^{5/2}} \approx z
\end{equation}
I get that the pressure is:
\begin{equation}
P = \frac {2} {3} \frac{NkT}{V}
\end{equation}
That result really bothers me because of that factor of 2/3. I did the same process to obtain the pressure and energy for bosons and obtained the correct result.
I thought that the factor may arise because I am considering electrons and the spin may do a contibution.
If anyone could help me with this it would be very appreciated!
Thank you
stevendaryl said:
They go through the calculation in this paper:
https://www.phas.ubc.ca/~berciu/TEACHING/PHYS455/LECTURES/FILES/fermionsn.pdf
They get ##PV = \frac{2}{3} U##, not ##PV = \frac{2}{3} kT## (where ##U## is the energy).
I found my mistake. I was assuming that
\begin{equation*}
\Gamma(5/2)=\frac{\pi^{1/2}{4}
\end{equation*}
when it actually is:
\begin{equation*}
\Gamma(5/2)=\frac{3\pi^{1/2}{4}.
\end{equation*}
Then everything was correct.
Thank you for your response, and I'm going to keep that paper. It's really interesting.
