Pressure is equal or force is equal at the bottom?
31 replies · 6K views
Again volume of both the fluid is same ; so the density. That means weighing machine would read same for both.
Pressure will be same at the bottom of container because it is dependent only on the height of water column.
In the first figure the slanted wall will exert force on the downward direction plus the weight of the fluid also acting downward, that will be compensated by larger flat base
In the 2nd figure slanted wall will exert force on upward direction, that will compensate only weight of the fluid; no need of larger flat base.
Moral of the story; same net force, same pressure on the bottom of the two tank.
Yes, that's correct. If one draws a free body diagram of a small patch of each container bottom, then the force applied to the inside is the same in both cases while the force applied to the outside of the elements changes depending on the bottom area. The net force on these elements must be zero. This additional force is applied at he edges of the elements and originates from stresses applied from the slanted walls.
