Effect of Air Bubble on Differential Pressure Measurement
The presence of air bubbles in a transmission line significantly affects differential pressure measurements when using electronic transducers. Key issues include process noise, where the bubble delays pressure transmission, leading to erroneous readings; offset errors due to the bubble's position in vertical segments of the tube; and system interaction, which can resonate with control systems. Purging the system is essential to eliminate air bubbles and ensure accurate measurements.
  • Understanding of differential pressure measurement techniques
  • Familiarity with electronic transducers and their operation
  • Knowledge of fluid dynamics, specifically Kirchoff's Pressure Law
  • Basic principles of system dynamics and resonance
  • Research methods for effective purging of transmission lines
  • Study the effects of process noise on measurement accuracy
  • Learn about the impact of fluid compressibility on pressure readings
  • Explore advanced differential pressure sensor designs and their specifications
Engineers and technicians involved in pressure measurement, particularly those working with electronic transducers in fluid systems, will benefit from this discussion.
can12345
What is the effect of air bubble in transmission line when measuring differential pressure by the using an electronic transducer? Purging is a must before measurement, however if we still have some bubble inside the transmission line or in front of transducer diaphragm, how it may effect to my measured values?
This is probably a question best addressed in the manual for the pressure sensor or by the application engineers at the company that made it.
You are asking (in essence), "How much is it going to hurt if I do not follow instructions?" That depends a lot on the specifics of the device which you have not provided, and I would tend to be skeptical of answers that do not have knowledge and experience with that specific transducer.
Three effects, two for sure and one maybe...
1. Process noise
To transmit pressure from one end of the tube to the other takes very little time so long as the contents of the tube are incompressible.
Short term fluctuations in system pressure should arrive at both sides of your dp sensor simultaneously so they'll cancel out.
An air bubble in one line delays transmission of pressure to that side, so system pressure fluctuations appear briefly as differential pressure . The sensor obediently reports derivative of system pressure in addition to whatever you're trying to measure, usually liquid level or flow.
2. Offset...
Draw the system and write Kirchoff's Pressure Law around it.
A bubble in a horizontal run does not add or subtract any head
but a bubble in a vertical segment of the tube adds error to your dp measurement in amount g*hbubble*(ρliquid - ρbubble )
3. System interaction..
The mass of fluid in the sense line and the compressibility of the bubble have a natural frequency just like any spring-mass system does.
Heaven help you if it's anywhere near that of a control system using the signal.
Get the air out.
old jim
  • · Replies 24 ·
  • · Replies 45 ·
