Pressure-Volume Work
  • Thread starter Thread starter Kakashi
The discussion revolves around the concept of pressure-volume work in a thermodynamic system involving a gas in a rigid cylinder with a piston. Participants explore the implications of gravitational force as a conservative force field and its relationship to path dependency in work done during gas compression.
  • One participant describes a quasi-static compression process of gas in a cylinder, emphasizing the balance of forces on the piston and the role of added mass in maintaining equilibrium.
  • Another participant questions the path dependency of work done by gravity, seeking clarification on how it applies in this context.
  • A different participant suggests that the change in gravitational potential depends on the center of mass of the gas, proposing that this resolves concerns about path dependency.
  • One participant presents equations relating initial pressure, added mass, and work done by the piston, indicating a mathematical approach to the problem.
  • A participant reflects on their understanding of path dependency in thermodynamics, noting that different processes (isothermal, adiabatic) lead to different pressure-volume relationships and work values.
  • Another participant expands on the concept of energy transfer, mentioning that energy can be supplied as both work and heat, indicating a broader view of energy interactions in the system.
Participants express uncertainty regarding the path dependency of work in this thermodynamic context. While some propose explanations and mathematical formulations, there is no consensus on the implications of gravitational force as a conservative field and its effect on work done.
Participants reference concepts from multivariable calculus and thermodynamics, indicating that the discussion may involve complex assumptions about state-dependent quantities and the nature of forces in the system.
Kakashi
Consider a gas contained in a rigid cylinder with a frictionless, weightless piston. The cylinder is in thermal contact with a thermostat at fixed temperature T. The space above the piston is evacuated. Initially, the piston is held by stops and the gas occupies a volume V1.
If the gas is compressed in a quasi-static matter do we envision the process as follows:
When the stops are removed, small masses are added infinitesmally on top of the piston so that it descends quasi-statically and compresses the gas to a final volume V2. At each step the piston is momentarily at rest and the gas pressure equals the external pressure.
At mechanical equilibrium, the force balance on the piston is
$$ \overrightarrow{F}=PA\hat{n}=mg\hat{n}$$
Where n is the unit vector perpendicular to the surface
$$ \int \overrightarrow{F} \cdot \overrightarrow{dz}=\int PA\hat{n} \cdot \hat{n} dz=\int PdV=\int m(z)gdz $$
Here, however, the mass m is not constant it changes as additional infinitesimal masses are added to maintain quasi-static equilibrium during compression and mass is the cause for the change in pressure.
I am confused because force of gravity is usually a conservative force field, implying that the work it does should be path independent.
Science news on Phys.org
What path dependency do you find in this case? I am not sure of it.
The change in gravitational potential would depend on the change of position of the CM of the body of gas. I think that would take care of your concern. If your integrals applied for a vertically symmetrical system (two pistons - one at the top and one at the bottom) would not conflict.
Initial pressure = ##P_0A=m_0g##, where ##m_0## is the finite amount of mass that must be added to the piston to hold it in equilibrium when the first stop is removed. We then have $$\delta P_n=g(\delta m_n)$$ and $$P_nA=g(m_0+\Sigma {\delta m_n})$$The work done by the piston on the gas is $$W=-\int{PdV}=-\int{PAdz}=-g\int{m(z)dz}$$
Appreciate everyones help.I didnt show path dependency. My question comes from recalling multivariable calculus, where the gravitational force is a conservative vector field and therefore its work is path independent. In the quasi-static piston setup, the external pressure is generated by gravity acting on the added mass, and the integral I wrot involves this gravitational force acting through a displacement of the piston.
I was trying to understand why the pressure–volume work is path dependent in thermodynamics. I now see that because mechanical equilibrium Pgas=Pext, and Pgas is a state-dependent quantity rather than a position-dependent force field. Different processes connecting the same states (isothermal, adiabatic, etc.) will lead to different p(V) and therefore different values of work.
The first law of thermodynamics : dU=dQ-dW
Energy can be supplied not only as work dW, which may originate from conservative forces, but also as heat dQ which depends on procedure.
State equation of gas : f(p,V,T)=0
##f(p_1,V,T_1)=f(p_2,V,T_2)=0##
Same volume but different pressure means different temperature.
The total work is path independent, but the path for adiabatic reversible is different from the path for isothermal reversible, and the final states of the gas differ for the same change in hight. In other words, the lmass variation vs z is not the only measure of the path.
At any point during the process, the pressure P is related to the mass m by $$PA=mg$$or $$m=\frac{PA}{g}$$Therefore, mass can be used as a surrogate for pressure.
For an isothermal path, $$mV=m_1V_1=M_2V_2$$
For an adiabatic reversible path, $$mV^{\gamma}=m_1V_1^{\gamma}=m_2V_2^{\gamma}$$
Therefore, the final states for these two different paths must be different.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 45 ·
  • · Replies 22 ·
