MHB How Can a Third Grader Identify Marks on a Number Line?
  • Thread starter Thread starter mathdad
To identify marks on a number line, a third grader can determine what each mark represents by counting the divisions between whole numbers. For example, if there is one mark between each pair of whole numbers, it indicates a fraction, such as 1/2. The Common Core Standards introduce fractions in third grade, making this a relevant topic for students at that level. Understanding how to represent fractions on a number line is part of the curriculum, which supports the idea that third graders can grasp this concept. Overall, with proper instruction, third graders should be able to identify and understand marks on a number line.
mathdad
Third Grade Math QuestionHow can you find what each mark represents on a number line? How does a 3rd grader answer that?
It is hard thinking like a third grader.
Here is my attempt:How can you find what each mark represents on a number line?
By counting the number of marks between each pair of whole numbers.
I drew a number line here. In this number line, there is one mark between each pair of whole numbers. Each mark must shows 1/2.
0--|--1--|--2--|--3--|--4--|-->
Is this an answer that a third grader would give?
Mathematics news on Phys.org
In what grade are fractions, and, in particular, 1/2, normally introduced?
Added: the "common core" introduces fractions in the third grade. So, yes, this is a reasonable third grade question.
Fractions are normally introduced in 5th grade unless it is an advanced third grade class. How would you answer this question as a third grader?
A search reveals that as HallsofIvy stated, fractions are introduced to students in the third grade according to the Common Core Standards, where they are taught (among other things):
1. Understand a fraction 1/b as the quantity formed by 1 part when a whole is partitioned into b equal parts; understand a fraction a/b as the quantity formed by a parts of size 1/b.
2. Understand a fraction as a number on the number line; represent fractions on a number line diagram.
a. Represent a fraction 1/b on a number line diagram by defining the interval from 0 to 1 as the whole and partitioning it into b equal parts. Recognize that each part has size 1/b and that the endpoint of the part based at 0 locates the number 1/b on the number line.
b. Represent a fraction a/b on a number line diagram by marking off a lengths 1/b from 0. Recognize that the resulting interval has size a/b and that its endpoint locates the number a/b on the number line.​
If those points are taught and grasped by the student, I see no reason why a third grader couldn't understand what each mark on a number line represents. :)
Well, when I was a third grader I would have answered "Uh, what?"
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
