Probability Density in an infinite 1D square well
9 replies · 3K views
gv3
The wave function of a particle of mass m confined in an infinite one-dimensional square well of width L = 0.23 nm, is:
ψ(x) = (2/L)1/2 sin(3πx/L) for 0 < x < L
ψ(x) = 0 everywhere else. The energy of the particle in this state is E = 63.974 eV.
1) What is the rest energy (mc2) of the particle?
ANS: 511133.6 ev
2) P(x) is the probability density.
That is, P(x)dx is the probability that the particle is between x and x+dx when dx is small.
For how many values of x does P(x) = 5 nm-1?
ANS: 6 values of x
3)What is the largest value of x for which P(x) = 5 nm-1?
ANS: ?
P(x)=∫|ψ(x)|2dx
E=h2n2/(8mL2)
For question 2 i only know its 6 because the question was multiple attempts. i don't know how to get that answer mathematically. I thought that by integrating P(x) squared and then solving for the x's would give me the 6 values of x but its not making sense to me. After i have the 6 values, then the answer to question 3 is just the largest value of x.
kuruman said:
You have all you need.
P(x)dx= ψ*ψ dx = (2/L) sin2(3πx/L)dx
Solve
P(x) = 5 nm-1
so set the integral equal to 5nm-1 right?
After integrating i get 5=(x/L)-(1/6π)sin(6πx/L) How do you even solve for x?
You don't integrate.. If you integrate x drops out and you get just a number, i.e. the probability that the particle be found within the limits of integration. You need to find at what values of x the probability density[/color] has the given value. It looks like you are confusing "probability" with "probability density". They are not the same.
kuruman said:
You don't integrate.. If you integrate x drops out and you get just a number, i.e. the probability that the particle be found within the limits of integration. You need to find at what values of x the probability density has the given value. It looks like you are confusing "probability" with "probability density". They are not the same.
Ok I got it. Thank you. The answer was .21 nm. Originally when I first solved it I got .021nm and the homework said I was off by a power of ten. Do you know why it could be off? Also could you explain to me why question 2 is 6 values of x
Solve
P(x) = 5 nm-1
I solved this and couldn't get 6. i tried with my calculator in radians and degrees.
Here is the plot of P(x) vs. x. Note that the 5 nm-1 line crosses the plot at 6 points.
Ah ok. I was graphing the wrong thing. Thanks for helping me! Sorry for the confusion.
