Probability- Exponential Distribution/Joint pdfs
In summary, the homework statement asks for the joint pdfs of (Y,Z), (Z,W), (Y,W). The question says that X1, X2 are independent, but this is not correct. Therefore, the student must find the joint pdfs of (Y,Z), (Z,W), (Y,W) by first finding the joint cdf and then integrating.
Zoe-b
98
Let X1, X2 be exponential RVs with parameter λ, μ respectively. (The question does NOT say that they are independent but I think this must be a typo?! If not I have even less idea how to do the question).
Let Y= min {X1, X2}
and Z = max {X1, X2}
Let W = Z-Y
Calculate the joint pdfs of (Y,Z), (Z,W), (Y,W). Which pairs are independent.
I know how to find the the pdf of Y, Z seperately (via the cdf) but this doesn't seem to be directly relevant. Clearly Y,Z are not independent, so I think I need to find their joint pdf by first finding the joint cdf and then integrating.
So far I have:
FY,Z(y,z) = P( Y < y, Z < z)
= P(Y,Z<y) + P(Y<y, y<Z<z)
= P(X1<y, X2<y) + P(X1 <y, y<X2<z) + P(X2<y, y<X1<z)
I really would like to know if this line is valid.. from here I used independence of Y,Z to find that
FY,Z(y,z) = 1 - exp(-y(λ+μ)) - exp(-λz) - exp(-μz) + exp(-μy-λz) + exp(-λy-μz)
for y<= z.
so
fY,Z(y,z) = 0 for y<z
= λμ(exp(-μy-λz) + exp(-λy-μz)) otherwise
This looks promising on the basis that the integral first wrt y from 0 to z, and then wrt z from 0 to infinity is 1.
But if I attempt to find the marginal distribution by integrating from 0 to ∞ wrt z, I get:
μexp(-μy) + λexp(-λy)
which is not what I would expect- I think the answer should be
(μ+λ)exp(-(μ+λ)y)
Am I even on the right lines at all? Its a much longer question but if this is wrong (as I fear it might be) there's not much point trying to plow through the rest using the wrong formulas..
Thank you!
Let Y= min {X1, X2}
Let W = Z-Y
So far I have:
for y<= z.
so
(μ+λ)exp(-(μ+λ)y)
Thank you!
I don't think your expressions for the joint distribution of (Y,Z) are correct. In fact, P{y < Y & Z < z} = P{y < X1 < z & y < X2 < z}.
RGV
Ok.. well better to find out its wrong now as I said :P
Erm.. slightly confused by what you wrote, I think I agree that
but seeing as Y,Z are not independent I then don't understand how I can relate this expression to P(Y<y, Z<z). Am I being incredibly slow?
If X1 and X2 are independent, you can easily compute P{y < X1 < z & y < X2 < z}.
RGV
Yes I know that. My question was I don't understand the relationship between
P{y < Y & Z < z} and P(Y<y & Z<z)
Obviously P(y<Y) = 1 - P(Y<y) but the dependence of Y,Z means I can't use this..
Your statement "Obviously P(y<Y) = 1 - P(Y<y)" is clearly wrong: we don't have A = 1-A for A = P(Y < y), as you are claiming.
I don't see your problem. If y = 3 and z = 5, are the numbers 3 and 5 dependent? Of course, Y and Z are dependent, but that is why I was careful to distinguish between y and Y and between z and Z.
RGV
RGV
Thats not what I wrote-
P(Y≥y) + P(Y<y) = 1
last time I checked... my notation made it confusing apologies- the capitals were the other way around.
However I'm definitely still missing something here.
P(y < Y & Z < z) = P(Y>y, Z<z) ≠ P(Y<y & Z<z) = FY,Z(y,z)
So knowing the thing on the left does not help me find the thing on the right.
Knowing P(Y>y & Z <z) is enough to determine the joint density f(y,z), but if I tell you how, I would be doing your homework.
RGV
Its actually a tiny part of a very long question that I'm taking as part of an optional course. So you're hardly doing my homework. But anyway. Thanks.
Sigh. I'll give it one more try. If you _did_ know the bivariate density f(u,v) of (Y,Z) at all relevant values of Y=u and Z=v, you could obtain P(Y>y & Z<x) as a two-dimensional integral of f. Write out this integral. Now it should be obvious how you can get f.
RGV
Let Y= min {X1, X2}
Let W = Z-Y
So far I have:
for y<= z.
so
(μ+λ)exp(-(μ+λ)y)
Thank you!
Sorry: I mis-read your expression for f(y,z) (recovering from a cold/flu and not at my best): your expression _is_ correct, but I thought the derivation more convoluted than need be. Much easier: {Y=y,Z=z} = {X1=y & X2 = z} or {X2=y & x1=z}. (Also, you would get this from the expression H(y,z) = P(Y>y,Z<z), using f(y,z) = -∂^2 H/ ∂y ∂z.)
Also: your marginal of Y was computed incorrectly: you should integrate over z from z = y to z = ∞.
RGV
Yes I had actually worked that out, but I was just about ready to give up when it gave me the same answer I got the first time. Thanks for all your help, I now have some chance of finishing the sheet in time :)
1. What is the Exponential Distribution?
The Exponential Distribution is a probability distribution that describes the time between events in a Poisson process, where events occur continuously and independently at a constant average rate.
2. How is the Exponential Distribution different from other probability distributions?
The Exponential Distribution is unique because it is a continuous probability distribution with a single parameter, lambda (λ), which represents the rate of events occurring. It is also a right-skewed distribution, meaning that most of the data falls on the left side of the graph.
3. What is the formula for the Exponential Distribution?
The formula for the Exponential Distribution is f(x) = λe^(-λx), where x is the variable and λ is the rate parameter. This formula represents the probability of a random variable taking on a specific value (x) in an exponential distribution.
4. How is the Exponential Distribution used in real-world applications?
The Exponential Distribution is commonly used in fields such as finance, insurance, and telecommunications to model the time between events, such as customer arrivals, machine failures, or claims made. It is also used in survival analysis to model the time to failure of a product or system.
5. What is a Joint Probability Distribution?
A Joint Probability Distribution is a multivariate probability distribution that represents the probability of multiple random variables taking on specific values simultaneously. It is often used to model the relationship between two or more variables and can be visualized using a joint probability density function (pdf) or a joint cumulative distribution function (cdf).
12K
