Probability of being in a state is given, Find the normalised wavefunction
10 replies · 2K views
dipanshum
A particle can be in two different states given by orthonormal wavefunctions ψ1 and ψ2. If the probability of being in state ψ1 is 1/3, find out normalized wave function for the particle.
ρ(r,t) = |ψ(r,t)|^2
where ρ= probability
Should I treat ψ1 as ψ and ψ 2 as ψ*?
What you have written down is not the probability of finding the particle in a particular state, it is the probability density of finding the particle at position ##r##. That the particle is in a state where it is in either ##\psi_1## or ##\psi_2## means that it is a linear combination of those states, i.e., ##\psi = \alpha \psi_1 + \beta \psi_2##. You need to find ##\alpha## and ##\beta##. (Note that there is an inherent phase ambiguity.)
Ok, I worked out the sum. Please tell me if I'm right.
The normalized wavefunction is:
ψ = 1/3 ψ1 + 2√2/3 ψ2
Orodruin said:
How do you compute the probability of being in the state ##\psi_1##?
The probability of ψ1 is given in the question.
What are the respective probabilities of finding the system in ##\psi_1## and ##\psi_2## using your ##\psi##?
no only probability of ψ is given, but that is sufficient data. and what you suggested already helped me and the answer is right.
what happened is after normalization one will get α22=1
then calculate and put values of α, β in the equation ψ=αψ1+βψ2
What's the probability of the state being ##\psi_2##?
Orodruin said:
It is not.
Okay so, yes Orodruin you are right, and I was wrong.
The final normalised function would be ψ=1/√3 ψ1 + √(2/3)ψ 2.
Tell me if I'm right this time.
