Solving Closest Values of x to Zero: Formula to Make it Easy
  • Thread starter Thread starter john425
    Problem solving
To solve the equation -30 sin(3x) = 1/10 cos(3x) for values of x closest to zero, one can transform the equation into a tangent form by dividing both sides by cos(3x), leading to -30 tan(3x) = 1/10. This formulation simplifies the problem by allowing the use of trigonometric identities. A right triangle can be used to visualize the relationship between sine, cosine, and tangent, reinforcing the understanding of the equation. Utilizing this approach can help find the two values of x that satisfy the condition. This method effectively streamlines the process of solving for x.
john425
I am having trouble solving for the two values
of (x) that are closest to zero.
-30 sin 3x = 1/10 cos 3x
Is there a formula I could use to make this easy?
Mathematics news on Phys.org
Write this as an equation in tan(3x)..
sin(x)/cos(x) = tan(x)
to see why this is true Draw a right triangle with hypotenuse 1 and an acute angle x, you can work the sides of the right triangle have lengths sin(x) and cos(x).
Oh yea! I just forgot!
Thank you!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
