Problem solving Heat Diffusion Equation
2 replies · 6K views · last reply
XCBRA
One face of a thick uniform layer is subject to a sinusoidal temperature variation of angular frequency ω. SHow that the damped sinusoidal temperature oscillation propagate into eh layer and give an expression for the decay length of the oscillation amplitude.
A cellar is built underground covered by a ceiling which 3m thick made of limestone. The Outside temperature is subject to daily fluctuations of amplitude 10 C and annual fluctuations of 20 C. Estimate the magnitude of the daily and annual temperature variation within the cellar.
I am unable to solve the first part of this question.
Take the diffusion equation
[tex]\frac{\partial T}{\partial t} = -D\frac{\partial^2T}{\partial x^{2}}[/tex]
Using separation of variable method:
Let [tex]T=X(x)F(t)[/tex]
[tex]X \frac{dF}{dt} = -DF\frac{d^2X}{DX^2}[/tex]
[tex]-D\frac{dF}{dt}=\frac{1}{X}\frac{d^2X}{DX^2}= k[/tex]
where k is the separation constant.
These separate into two equation which I solve to give
[tex]X=Ae^{\sqrt{k}x}+Be^{-\sqrt{k}x}[/tex]
[tex]F=Ce^{-Dkt}[/tex]
By superpositon principle
[tex]T=\sum (A_ke^{\sqrt{k}x}+B_ke^{-\sqrt{k}x})e^{-Dkt} + A_0 + B_0x[/tex]
where C has been absorbed into A and B.
Then taking the boundary conditions:
At x →∞ T→0, which shows A_k → 0
[tex]T=\sum B_ke^{-\sqrt{k}x}e^{-Dkt} + B_0x[/tex]
Then apply conditon that at x=0 T [itex]\propto[/itex] sinωt.
[tex]e^{-Dkt} = sinwt[/tex]
However here is where I am stuck, I do not see how proceed further. Is my solution so far correct, it does not seem so as I seem to have the wrong form. Or have I chosen the wrong form for my separation coefficient?
Any help would be greatly appreciated.
The transient heat equation is generally written without the negative sign as you have written it. When you use separation of variables, use -k as your separation constant. That causes the X(x) portion to be sines and cosines.
Ahh that makes better sense. Thanks for the help, I was able to solve to give:
[tex]Tcos(wt-x\sqrt{\frac{w}{2D}}) e^{-x\sqrt{\frac{w}{2D}}}[/tex]
